585,743 active members*
4,837 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > V2x Siemens Lathe Posts
    Hi Guys,
    Anyone have the Siemens lathe posts from the old PP library? They're all crap but I could do with a starting point to edit rather than writing from scratch.
    I should have systematically downloaded all posts when I considered doing a year or so ago as BCC have now "Lost" (Deleted) the lot and support have informed me that I can simply buy a new version to get access to a shoddily thrown together PP for the latest version!
    Aug 2009
    1570
    Re: V2x Siemens Lathe Posts
    ...V23 BC post files but, I never used them (untested)
    Thanks for those, still looking for a Siemens Lathe post if anyone has one?
    Aug 2009
    1570
    Quote Originally Posted by magicniner View Post
    ...you do know there is a App called LatheEditPost.exe in BC. its a little tricky but, you can make what ever PP you need.
    Attachment 449114
    Attachment 449116
    [QUOTE=machinehop5;2403442]...you do know there is a App called LatheEditPost.exe in BC. its a little tricky but, you can make what ever PP you need.
    Yes,
    Thanks, the reason I'd like to start from a Siemens post as the canned cycles, although BC usually got lots of the passed parameters mixed up, will be present,
    Regards,
    Nick
  1. Posts for Fanuc 6T , lathe
    By turbosvinkovci in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 10-05-2016, 11:59 AM
  2. Lathe Posts to Mach3 Mill?
    By rcsimpson in forum BobCad-Cam
    Last Post: 10-31-2008, 05:05 PM
  3. Lathe c-axis posts
    By edmaster in forum DNC Problems and Solutions
    Last Post: 05-22-2007, 03:38 AM
  4. Lathe Tool Posts
    By ozzie34231 in forum Uncategorised MetalWorking Machines
    Last Post: 05-18-2005, 05:31 AM
