585,885 active members*
6,253 visitors online*
Results 1 to 8 of 8
    machine won't reset
    was cutting small project 5 in by 5 in and power supply browned out, meaning fluxuated and machine now wants to cut project size of 12 in by 12 in,I can't get it to reset to original size of 5 by 5. have reset all parameters on machine and reloaded program from computer to usb stick and it still wants to cut 12 by 12. can anyone please advise me what to do?
    Re: machine won't reset
    Some info about your machine might help.
    Aug 2009
    1573
    Quote Originally Posted by newtothiscnc View Post
    change them back maybe to before you changed them
    i have a STG6090 4 axes from Style company out of beijing china
    water cooled spindal 220 VOLT plus have converter for 110 volt US to 220 volt europian
    with a DSP A11E controller
    Quote Originally Posted by machinehop5 View Post
    did that no change
    I have also gone back into my collection and pick a project that I have completed successfully. and I cannot get it to recognize it. it just waants to go back to the 12 by 12
    What cam package are u using? Are u sure the power supply issue is fixed? What caused the power issue?
    Apr 2004
    5737
    It might have corrupted the steps per unit settings when the power went sideways. Have you checked that, by commanding a move of known length and comparing expectation to achievement?
    Andrew Werby
    Website
  1. ATC Reset every time I turn on my machine
    By cobrakai in forum Tormach Personal CNC Mill
    Last Post: 12-28-2016, 04:27 AM
  2. ERROR 449 Cant reset machine
    By stringer in forum Uncategorised MetalWorking Machines
    Last Post: 05-03-2012, 11:48 PM
  3. Machine Hours Reset???
    By WGJ in forum Haas Mills
    Last Post: 01-26-2012, 05:38 PM
  4. Reset offset after turning machine off?
    By behindpropeller in forum Haas Mills
    Last Post: 11-23-2010, 10:33 PM
  5. machine reset parameter
    By priyo in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-28-2007, 07:45 AM
