584,808 active members*
5,126 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Bridgeport Torq Cut 2G heidenhain tnc 370 Machine is not moving no homing PLZ HELP
    Jan 2013
    19
    Hello my Bridgeport Torq Cut 2G VMC machine with heidenhain tnc 370 controls has frozen , Nothing is moving its no Axis is referencing to home position ...Dont know what to do anyone please advice how to go about this & what to do ...PLEASE HELP ME ...
    The Alaram is showing as Z Axis Motor Overheat..
    and i also need the PLC paramenerts the controls heidenhain tnc 370
    NC 280600 13
    PLC 278215 11
    HELP will be much appreciated ..
    May 2013
    Re: Bridgeport Torq Cut 2G heidenhain tnc 370 Machine is not moving no homing PLZ HEL
    I had the same machine with the same problem. Check the Z axis limit switches one of mine was broken.
    Jan 2013
    19
    Quote Originally Posted by jamesclerie View Post
    Sir please help me , Can you get me the electrical & PLC parameters manual , Or can you atleast send me the PLC parameters ...This will be of great help the machine has been idle for more than a year now ...PLEASE help
  1. How do you use your MP-11 Probe on your Bridgeport Torq Cut machine?
    By Steve_Watkins in forum Bridgeport / Hardinge Mills
    Last Post: 08-30-2017, 11:31 PM
  2. Bridgeport torq cut tc3g heidenhair manuals needed
    By Barlow218 in forum Bridgeport / Hardinge Mills
    Last Post: 11-11-2014, 10:55 PM
  3. Bridgeport Interact w/ Heidenhain 151B - Traverse Speeds for Homing Axes
    By jmccracken in forum Bridgeport / Hardinge Mills
    Last Post: 12-30-2011, 10:58 PM
  4. Machine parameters for a bridgeport 560/22 with heidenhain 370
    By dws_engineering in forum DNC Problems and Solutions
    Last Post: 12-12-2010, 11:16 AM
  5. Graphics in Bridgeport machine with HEIDENHAIN TNC 155
    By hartan in forum Bridgeport / Hardinge Mills
    Last Post: 09-16-2009, 08:52 PM
