585,715 active members*
3,926 visitors online*
Results 1 to 10 of 10
    Feb 2020
    11
    DIY Preload on a ballscrew
    Greetings.
    I'm the owner of some very cheap chinese C7 (so they say) rolled ballscrew. Diameter 20mm/pitch 5mm.
    Obviously backlash is present and in a reasonable amount for the price but yet too big for my purpose. I was thinking about putting a double ballnut without replacing the screw but it is hard to find dealers that sell only the nut and also I'm not sure if I want to spend money on upgrading something that is not good in the first place (accuracy of the pitch isn't great too).
    So I was wondering if it is possible to just replace manually the balls inside the nut and replace them with slightly bigger ones so to give preload to the screw.
    Did someone ever tried to do this? Any suggestion on how much each ball bearing should be bigger (I have plenty of torque with the motors and I don't care too much about the life of the ballscrew)?
    Thanks.
    Apr 2020
    44
    Re: DIY Preload on a ballscrew
    Hi Stefano.
    I am currently working on improving the chinese clone Hgr and ballscrews, and can tell their sizes vary quite a lot, so it is trial and error.
    I just finished my hgr 20, and had to use 5/32" in -10 to -2um steps, and as there are 132 balls in each car it is a litle time consuming, but came out very well.
    Now I am working on 1605 ballscrews, and plan to work up in sizes so 2005 will be next, but it takes a long time to get the right size balls, and they tend to be quite expensive in the g10 or g16 I buy, but still very cheap compared to the real ones, even hiwin.
    Later I can make a thread showing how to reball and what sizes to use, but to answer your question, first measure all the balls in the screw find the biggest size and reload with a grade 10-16 of that size. if you still have play, go 2um (0.002mm) up in size, but be aware that more preload is more wear, so proceed with caution.
    Good luck, Mike.
    Feb 2020
    11
    Hi Mike,
    Thanks for the answer. Hope to see your thread soon.
    Good luck with your project.
    Dec 2005
    436
    Mikeedd: can you post a link to the provider of the oversize balls you purchased? And if possible how you did the process?
    Apr 2017
    67
    Quote Originally Posted by Mikeedd View Post
    Hi Stefano.
    Good luck, Mike.
    I am also interested in your process and where you obtain the balls. I got some cheap HGR20 linear rails and found them to be very gritty. I removed the balls, cleaned them, cleaned the ball guides, reassembled, much better but very time consuming. My thought was to just discard the balls from the remaining carriages (there are a lot of them) and replace with brand new. But I could not find a source of balls. The balls seem to be a nonstandard size. Very close to 5/32" but not quite.
    15362
    Hi Stefano.
    Good luck, Mike.
    To reload a Ballscrew every other Ball has to be smaller or they will bind, so yes find the size that works and then use what is called a spacer ball between each ball the spacer balls are normally around .0002" to .0005" smaller, that is why when you take a Ballscrew apart you will find different size Balls, Quality Ballscrews and Linear Rails Bearings use a plastic cage between the balls to stop the ball to ball binding
    Mactec54
    Apr 2017
    67
    You stated that like a law of physics but is it? I have seen it contested. I'm not contesting it, and I don't have an opinion either way, just bringing up the fact that there are other opinions. I don't know enough to have an opinion.
    15362
    Quote Originally Posted by strantor View Post
    Then why did you post, this is how all manufactures make them, take a quality Ballscrew apart and you will find out for yourself NSK THK Bosch SKF Hiwin Etc
    Of course you can reball your Ballscrew how ever you like your C7 Rolled screws are not going to notice how you reball them, they are still going to be a C7 low quality Ballscrew and sound like you assembled them with a bag of grit when you have finished
    Mactec54
    Apr 2017
    67
    I re-read my post it does not sound good. I came across badly. I apologize. I was trying to start a discussion about the physics behind using spacer balls vs not.
    Months ago I took apart my NSK ground ballscrew/ Ballnut out of my CNC and at first I thought I had confirmed that they use two different sized balls. I was grouping them in two different cups. Soon I realized I needed a 3rd cup. Then a fourth. Depending on where I drew "the line" I may have needed 6 or 8 cups. I went back and started measuring the balls in the cups again, and got different measurements than I did the first time around. I realized that the balls were out of round.
    I re-balled that nut using all same-sized balls, as I could not determine whether it originally had two sizes of balls, or what sizes they may have been. At that time I found conflicting information in forums about all-same-size vs spacer balls. I did not understand the argument for spacer balls but it seemed like the preferred method despite cutting the contact/thrust surface in half.
    I have not had any issues from it, but I dont know how it will turn out in the long run. I have barely ran it. I don't know if I made a mistake or not and I'm apprehensive. I was hoping someone could explain better than what I've read so far. That is why I posted.
    Again, my apologies for the way I worded it. I meant no offense.
