585,605 active members*
3,142 visitors online*
IndustryArena Forum > CNC Electronics > Phase Converters > Unknown Huanyang error code EEP
    Nov 2008
    24
    I have a Huanyang HY02D223B on my milling machine.
    We had a power outage today and now I have no power to the mill spindle and the display reads EEP. Pressing the reset button flashes the F00.00 message and then returns to EEP.
    I've searched the manual and other online resources but can't find this particular code.
    Anyone know what it means? Does it mean it's time to buy a new inverter?
    15362
    Re: Unknown Huanyang error code EEP
    Quote Originally Posted by sliptonic View Post
    It is either a CPU fault or an E'prom fault
    Was this running when you had the power outage as it could well be the IGBT's as well if it was running and had a power cut
    How has the input power been wired to the VFD Drive and is this single phase or 3 phase supply
    Mactec54
    Nov 2008
    24
    The VFD was powered on but not running when the outage occurred.
    This is single phase supply. 220 wired into the mill cabinet and enabled through relay so it turns on with the rest of the mill.
  1. UNKNOWN FAULT CODE
    By CNC_BOB in forum OKK
    Last Post: 11-18-2022, 07:57 PM
  2. Huanyang 2.2kw VFD error code E.oU.5 or EoUS or EoU5
    By Ozzwinkle in forum Phase Converters
    Last Post: 05-15-2020, 11:59 PM
  3. Unknown G code
    By cnczoneguy in forum G-Code Programing
    Last Post: 10-26-2012, 05:23 AM
  4. G65... unknown G code?
    By omgtim in forum Fanuc
    Last Post: 04-19-2010, 08:46 PM
  5. Unknown g code G23 error?
    By keaton64 in forum Mach Plasma / Laser
    Last Post: 09-22-2009, 03:33 AM
