585,885 active members*
6,203 visitors online*
Results 1 to 2 of 2
    Jan 2018
    44
    PM-30 Build Suggestions
    I am weighting my options on upgrading my CNC from a converted Harbor Freight Mini Mill to a PM-30. I like that you can squeeze extra y travel out of the 30 and that it has a decent sized belt driven spindle/motor out of the gate. Since I already have a small cnc mill, a cnc router, and a manual mill i was considering building my own conversion kit. I was wondering if anyone had made a G0704/pm-25 conversion work on one of these. I also am considering just buying a conversion because I am slowly and painfully milling parts that I sell online on my current machine. I am eager to get up and running and think the purpose built conversion could be done quickly and efficiently.
    My second question is does anyone know how many rippems (rpm) the factory spindle bearings can handle on one of these bad boys? If I were to change the ratio of the belt drive how fast can I go? I am not looking for blistering speeds but I will be using this machine for small production runs and the more rpm I can get the better.
    Any other insight on common issues one might encounter while converting one of these machines would also be awesome!
    I plan to use closed loop nema 34's and linuxcnc.
    May 2008
    1185
    Re: PM-30 Build Suggestions
    The PM-30 has Tapered Roller bearing stock. They are a strong bearing but will make a lot of heat at higher speed. Most all the bench top run them.
    Breaking takes a long time lets say 20 hours. If you have the preload sett correctly you can run 4000 to 5000 RPM and not over heat on long runs.
    The stock RPM is 3K and getting to 4 or lets say 4500 should be fairly easy. For faster you will want to go to new AC bearings and really, if you run larger cutters at all, a larger motor. The 30 is just large enough to fit a 56C size motor.
    The 30 does give over 8" of Y. It is a nice move up from the mini mills.
    I also make a kit for them.
    Dave
    youtube videos of the G0704 under the name arizonavideo99
  1. New DIY build - design suggestions/ideas welcome
    By zeeflyboy in forum DIY CNC Router Table Machines
    Last Post: 04-13-2021, 06:25 PM
  2. $5000 machine build, need suggestions
    By cncmadness in forum DIY CNC Router Table Machines
    Last Post: 03-03-2014, 07:19 PM
  3. WANT TO BUILD MILL. LOOKING FOR SUGGESTIONS
    By onlyinutah in forum Uncategorised MetalWorking Machines
    Last Post: 05-21-2013, 11:25 PM
  4. Need suggestions for CNC build
    By Knas in forum Open Source CNC Machine Designs
    Last Post: 11-22-2012, 12:55 AM
  5. New Build - Need help and suggestions
    By roadharley2 in forum Knee Vertical Mills
    Last Post: 05-05-2009, 02:22 AM
