586,000 active members*
4,834 visitors online*
IndustryArena Forum > CAM Software > ArtCam Pro > Tutorial for simple rotary engraving
    Aug 2020
    I recently got my first cnc and use it with ArtCam 2018 and Mach3. I did some simple engraving and cutting pieces in flat materials and everything went smoothly. Now, I decided to try engraving on the rings.
    Where can I find a tutorial how to do simple engraving on rings, so I can solve the following problems:
    - Every engraving I make in ArtCam in Mach3 is mirrored (fliped horizontally)
    - How can I most easily determine zero correctly on the x, y(a) and z axes?
    Regards,
    Midhat
    Re: Tutorial for simple rotary engraving
    Autodesk----> ArtCAM forum + Mach3/4 pdf tutorials.
  1. Laser Engraving Advanced Tutorial
    By Nolan Yang in forum Videos
    Last Post: 11-01-2017, 08:50 AM
  2. Replies: 1
    Last Post: 12-30-2015, 08:16 AM
  3. Rotary Tutorial
    By bsimages in forum Vectric
    Last Post: 04-27-2011, 10:16 PM
  4. Tutorial for simple lasercutting?
    By kongen867 in forum Solidworks
    Last Post: 05-28-2010, 03:56 PM
  5. Rotary Tutorial for Aspire & V-Carve
    By rcnewcomb in forum Vectric
    Last Post: 05-17-2010, 12:06 AM
