585,977 active members*
3,966 visitors online*
Results 1 to 3 of 3
    Nov 2008
    Upgrading an aging machine
    I have an old Kern Laser with a ULS 50w cart. The machine works ok but the controller and software are quite old. The KCAM is on a 98 box and the interface is an ISA card so I'm rather stuck using anything newer.
    I was wondering if anyone had undertaken a similar project to convert one of these aging machines to run off a newer controller that would allow use of LaserCAD or LightBurn or something. It would be nice to be able to get a few more software related features out of the system.
    If not, is there something relatively inexpensive that I could get as a new table that would accept a ULS 50 cart? The cart was recharged not long ago and is in good shape. If there's some 'bed with a controller' that has the capability to plug in a ULS cartridge that might be the way to go.
    Thanks!
    Feb 2012
    41
    Dec 2006
    124
    Re: Upgrading an aging machine
    Quote Originally Posted by thelanranger View Post
    Thanks!
    With the rock solid chassis and good motors on your machine, it is better to upgrade because most of the "affordable" machines out there are much lighter weight and less accurate. So, the key for the upgrade is to match the motor drives to the new controller, then the limit switches will also get done. We have done a few upgrades, though each machine is a bit different.
    If you do take the ULS to another machine, just make sure the controller is putting out the tickle pulse as specified in the OEM user manual for your laser, otherwise the tube will not operate nearly as well and will likely fail prematurely.
  1. Upgrading a Standard machine to Pro
    By nlancaster in forum Avid CNC
    Last Post: 10-31-2018, 06:01 PM
  2. Laptop Monitor Dimming and Aging
    By kevinmanuel in forum Computers / Desktops / Networking
    Last Post: 04-17-2018, 07:50 AM
  3. Upgrading a K40 moshidraw machine to DSp
    By Scottbgv in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-10-2014, 07:07 AM
  4. Upgrading dos machine
    By alan.styer in forum Commercial CNC Wood Routers
    Last Post: 06-12-2011, 02:36 PM
  5. Aging Tube? Characteristics?
    By FlyGuy007 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-06-2009, 06:34 AM
