585,698 active members*
3,618 visitors online*
    Aug 2018
    12
    How to disable M62
    I have a MK2 controller on my CNC router. I am in the process of adding a laser to it. I need a 15-sec delay at spindle start for the bit to spin up, but I do not want a delay when I use the laser. If I use M62 to fire the laser, how do I turn it back off? Is there a better way to do this?
    Nov 2015
    260
    Re: How to disable M62
    In the settings you can set how long you wait after a spindle start.
    Otherwise, I don't know if the TNG v2 software can do that, but give it a try.
    M62 Turn on digital output synched with motion
    M63 Turn off digital output synched with motion
    M64 Turn on digital output immediately
    M65 Turn off digital output immediately
    Aug 2018
    12
    Quote Originally Posted by tantemay View Post
    Thanks, I didn't think I could run TNG with a MK2 board. I'll have to try this with a demo installation...
    Mar 2017
    1304
    Mk2 will not work with TNG.
    You can use M62 to turn output on and off.
  1. how can i disable air on this little one ?
    By deadlykitten in forum Okuma
    Last Post: 08-28-2016, 11:21 AM
  2. VSD-A Disable Pin
    By JerryFlyGuy in forum CNC Machine Related Electronics
    Last Post: 09-01-2011, 11:58 PM
  3. G203v disable pin
    By kae in forum Gecko Drives
    Last Post: 02-17-2010, 02:55 AM
  4. How do you disable SMI?
    By CROSSHATCH in forum LinuxCNC (formerly EMC2)
    Last Post: 03-04-2009, 10:22 PM
  5. Disable with Mach
    By belli in forum Mach Plasma / Laser
    Last Post: 07-14-2007, 09:53 PM
