585,931 active members*
5,311 visitors online*
IndustryArena Forum > MetalWorking Machines > Drilling- and Milling Machines > Robodrill X axis refusing to relearn
Results 1 to 2 of 2
    So I’ve just got this Fanuc Robodrill after it’s sat for years, after powering it up, I got alarms for battery and all 3 axes needing to relearn home position. Replaced battery, powered off and back on, that solved the battery alarms, but now trying to relearn the axis positions, I got Y and Z to cooperate rather easily, but each time I try X I manually move to the position, with the two diamonds aligned, and hit the soft key 3x as instructed, and after the third press of the soft key it moves (negative) in X until it hits the hard limit and alarms due to servo over torque. I’ve repeated the process multiple times, with the same result. Do I have a bad limit switch or something? Searched the forum and google several times with nothing quite matching my needs. Thanks!
    Re: Robodrill X axis refusing to relearn
    Well disaster averted. After 10 or so failed attempts, I took apart the encoder and just looked to see if it needed cleaning or something, was clean as a whistle, but after reassembling, resetting the axis zero worked on the first try, so must have been just a bad connection at the plug… got off lucky I guess, but hopefully this experience helps someone else.
  1. Fanuc Robodrill Z axis variation
    By HiramGL in forum CNC Machining Centres
    Last Post: 08-09-2021, 04:20 PM
  2. Replies: 2
    Last Post: 12-10-2018, 10:59 PM
  3. New Fanuc Robodrill or 7000 hour robodrill with all the bells and 4th axis?
    By The_R1_Kid in forum Uncategorised MetalWorking Machines
    Last Post: 09-20-2018, 01:26 PM
  4. Robodrill z axis alarm
    By ikhwan in forum Fanuc
    Last Post: 12-09-2012, 06:57 AM
  5. PMDX 107 to Huanyang - refusing to work
    By jestah in forum DIY CNC Router Table Machines
    Last Post: 02-07-2011, 03:24 AM
