585,763 active members*
4,232 visitors online*
    DIY 5 axis CNC Router
    I need your opinion on this. Planning to build this 5 axis CNC Router.
    This is rough concept.
    Jan 2008
    1529
    Re: DIY 5 axis CNC Router
    Unsupported rails = cooked spaghetti. Floppy.
    Apr 2007
    273
    maybe look at a Haas UMC for some direction on design. they work well and seem to be similar to what you are looking for in movement. i'm not sure how important the horizonal configuration of the spindle is to your needs but the Haas might give you some design ideas. i would go with a square style linear rail opposed to the round rails. like the previous person said you are going to need support everywhere. i would think the rotary combo hanging out as shown will become a problem area pretty quickly. not to mention the weight factor of that part of the design when it comes to raising and lowering that end.
    https://youtu.be/uc5P6Ss3LRE
    1218
    What software do you plan to use for generating the programs?
  1. Replies: 4
    Last Post: 09-19-2023, 01:39 AM
  2. Replies: 0
    Last Post: 08-04-2013, 05:30 AM
  3. Buying a new 48x48 Art-Router 4 Axis CNC Router
    By Stoch in forum Open Source CNC Machine Designs
    Last Post: 12-17-2010, 01:08 PM
  4. New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter
    By the__extreme in forum CNC Wood Router Project Log
    Last Post: 02-26-2007, 09:58 PM
