585,737 active members*
4,529 visitors online*
    Replace outdated oem software
    I just wanted to get some opinions. I have a few diffent cnc routers in my shop. The software and drive controllers are no longer supported by the OEM. I have vendors who can do repair work on the amps, drives and motors. What I was think about is upgrading the pc that drives the motion to something with an open source software. What's would be the pros and cons in this?
    Nov 2005
    222
    Re: Replace outdated oem software
    I can't really list pros and cons as I am not familiar with older OEM controls you should take a look at LinuxCNC. It's free, runs on very inexpensive PCs and will run any machine you can think of. There is also very active and excellent support one the LinixCNC forum. See https://www.linuxcnc.org/
    May 2015
    686
    +1 for linuxcnc and also for some mesa cards for basically unlimited IO plus servo control.. Look through their forum at some of the retrofits done.
    Rod Webster
    www.vehiclemods.net.au
    What specific machines do you have? If they are old big Italian routers, they may use custom g-codes to control certain functions, and you may lose some functionality.
    May 2015
    686
    There will be workarounds with Linuxcnc but the gcode command may need to change... You should not loose functionality if you put the effort in to ensure all functionality is retained...
    Rod Webster
  1. Deleting unused and outdated components
    By persei8 in forum Autodesk
    Last Post: 07-01-2019, 01:36 AM
  2. How to replace RDCAM 5.1 Laserworks Software?
    By IvanCorrea in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-24-2012, 03:15 PM
  3. New 828D with outdated S7-200
    By pepp-eric in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 09-17-2009, 07:29 PM
  4. Older Bridgeport with outdated cpu
    By Greg_B in forum Bridgeport / Hardinge Mills
    Last Post: 05-20-2009, 10:20 AM
  5. Need outdated supermax part.
    By Crashmaster in forum Uncategorised MetalWorking Machines
    Last Post: 01-14-2009, 09:07 PM
