585,578 active members*
3,893 visitors online*
Results 1 to 15 of 15
    Jul 2016
    17
    PlanetCNC TNG software crashing
    Hello,
    Problem: PlanetCNC TNG software crashes/closes down if I press the following; settings and license management options.
    Software version: 2020.09.18
    I tried solving the problem by adding PlanetCNC to Windows Firewall exception lists and restarting the computer, but no use.
    Question 1: Are there softwares or drivers that are required for PlanetCNC to work properly, and what are they?
    Question 2: how do I overcome the crashing problem.
    Mar 2017
    1304
    Re: PlanetCNC TNG software crashing
    Anybody else experiencing crashes with 2020.09.18 version?
    Pend me profile .zip file
    Jul 2016
    17
    Quote Originally Posted by PlanetCNC View Post
    Sorry I am not able to provide you with Profile.zip file, PlanetCNC TNG crashes after I press export profile save.
    Mar 2017
    1304
    Windows, Linux, MacOS, RPi?
    Jul 2016
    17
    Windows 10
    Jul 2016
    17
    Computer Information
    Windows 10 Pro x64
    CPU AMD Ryzen Threadripper 3970X
    GPU GeForce RTX 2080 Ti
    Motherboard ASUS TRX40-PRO
    Apr 2013
    110
    I replied to S3eed77z in PM but it seems correct to write it here as well as it can help someone with the same problem.
    The problem complained by S3eed77z is the same as the one I had a few months ago when I changed the old Intel PC to a new one based on AMD processor in particular with Asus motherboard. The anomaly is caused by some USB 3.0 ports that conflict with MK3 controllers (both 9 and 4). I haven't found a permanent solution even by updating all the drivers available for my Asus motherboard but I am able to make full use of my MK3-9 by temporarily disabling the USB ports causing the problem
    Mar 2017
    1304
    Menu "Help/Show Log..." - does it crash?
    If not - log window has buttons on left side to show USB devices/properties. Does this crash?
    Jul 2016
    17
    If I press the USB sign, it crashes.
    Device not connected.
    Jul 2016
    17
    Controller LEDs
    Power green constant
    Data orange constant
    Link orange constant
    Status green blinking
    Mar 2017
    1304
    Seems like an USB device is causing crash in our USB enumeration procedure.
    I've reexamined our code and I added some additional safeguards but I was unable to pinpoint problem.
    Can you disconnect all USB devices from computer and try again. Perhaps you can find which one it is.
    Jul 2016
    17
    Can I just use LAN?
    Mar 2017
    1304
    You can use LAN but this will probably not help with "License" and "Log" dialogs.
    Jul 2016
    17
    Currently I will use my old laptop, and when this problem is resolved I’ll change provide my computer code to switch users.
    Mar 2017
    1304
    I'm trying to get computer with Asus Prime MTB so that I can test this.
  1. Replies: 27
    Last Post: 05-12-2020, 09:17 AM
  2. Replies: 2
    Last Post: 02-24-2020, 10:59 PM
  3. Is the PlanetCNC software license transferable?
    By retrosmith in forum PlanetCNC
    Last Post: 01-23-2019, 02:25 AM
  4. Need help - wiring PlanetCNC Mk3/4 with 1.5kw VFD
    By billet works in forum Spindles / VFD
    Last Post: 03-29-2018, 07:13 PM
  5. Software Crashing
    By fidia in forum BobCad-Cam
    Last Post: 09-30-2012, 11:47 AM
