585,959 active members*
4,309 visitors online*
    Question Ringing Router Bit
    I read somewhere that 1/4" shank carbide bits tend to ring.
    Boy do they ever! I'm using an Onsrud 52-285 (upcut 2-flute 1/4", 1/4 shank) in 3/4" BCX plywood.
    What is the ringing telling me? Can I reduce it by adjusting feed, rpm, DOC?
    Feb 2005
    829
    Re: Ringing Router Bit
    Probably too much RPM for the material, or not enough IPM. Basically you are not taking a good cut for each flute on the tool.
    I use single flute cutters on my CNC Router, they work much quieter and give a better chip.
    What RPM, IPM, DOC are you cutting at?
    Quote Originally Posted by nlancaster View Post
    DOC 6mm, 1200mm/min. 10-12krpm.
    My feed rate is limited, my poor machine design. I haven’ t tested running any faster. I could drop to 8krpm but that is the low limit of my router, I don’t know how well the speed regulator will work.
  1. DC servo hot plus strange ringing noise
    By bgolash in forum Gecko Drives
    Last Post: 10-20-2014, 12:11 PM
  2. Ringing and bad finish while parting 303ss
    By dingo0722 in forum MetalWork Discussion
    Last Post: 10-26-2011, 03:42 AM
  3. VFD Ringing noise
    By bigalow in forum Phase Converters
    Last Post: 03-09-2008, 04:12 AM
