585,764 active members*
4,233 visitors online*
Results 1 to 19 of 19
    Nov 2006
    28
    Servo 300 Bar Feeder
    We are having trouble programing a bar feeder on an SL20. We can get the stock to load and the push rod to activate, but can not get the stock where we want it. Does anyone have a sample program that works that I can load and pick apart to see this thing operate?
    May 2005
    94
    we are just getting ours running too. on current commands page press page up until you get to the bar feed page. enter all your length #'s there. then jog the rod to push a bar flush with the chuck/collet face. go into mdi and enter g105 Q2. machine will push bar entered length on bar feed page. the end of my program just has a G105 in it, then the control references all your parameters on the bar feed page again.
    look in your bar feed manual on page 17-18
    Nov 2006
    28
    We figured it out. We found the screen with all the variables. Also that you can use I J and K as over rides. It's pretty interesting to see the thing work.
    Aug 2005
    578
    OK I have an order of 5000 pcs for my SL10. part is 2.5 long from 1/4 inch alum. I face center and drill an1/8th inch hole about 3/4 inch deep na dpart it off. The initial push is set at .35. I face center and drill it. Call a G105 and push it 2.645. Dandy....
    Now I got to push the green button 5000 times. How do I get it to repeat the 13 times for one bar?
    Yes I have the bar length in the page and the number of pcs per bar in there as well. And THEN.....How do I get the thing to automaticaly load another bar so it'll just run the stinkin job??????
    Can ya tell I'm just a tiny bit frustrated?
    Jul 2005
    12177
    Quote Originally Posted by PBMW View Post
    ...Now I got to push the green button 5000 times....
    Isn't that what you hire Green Button Pushers for?
    Aug 2005
    578
    Au Contrare'
    That's why them Green B utton Pushers got ME!!!! So they can have work to push the green button for!
    So what I got to do to make this thing run?
    Jul 2005
    12177
    Au Contrare'
    Don't ask me...I was too cheeeeep to buy the fancy Haas barfeed and built my own.
    Can't you put things into a subroutine that you call 13 times or something like that?
    Aug 2005
    578
    Well, Yea, I'm thinkin I can. But I've not done that before and thus have no idea how it's done....
    Hence my question
    Jul 2005
    12177
    Hence my question
    Something like this, there is stuff missing of course;
    Program Name
    Subroutine call M97 P1000 L13
    Home axes G28
    Stop program M30
    N1000
    All your stuff for doing the first push
    Face and drill
    Second push
    Part off
    M99
    What this does is go to line N1000, runs through the sequence, push, face, drill, push and part off and repeats this 13 times.
    This doesn't help you start a new bar and I have no idea how that is done. One thing I do know is that if you just let the stub end from the first bar drop out into the chip tray and you have a chip auger you may need a new one when it grinds itself apart on the bar stub.
    If you like I can find one of our programs that does this subroutine stuff and post it. You could load it and look at it in graphcs to see the sequence.
    Aug 2005
    578
    That would be very cool.
    So, if I understand you correctly, the program that calls "my" program is the "O" numbered program and the sub ("My" program) is labeled with a "P"?
    Jul 2005
    12177
    No the "My" program is tacked on the bottom of the "O" program right after the M30 and starts with line number N1000. The command M97 P1000 L13 just says; "scan through this program until you find line N1000 and start from there. When you reach the M99 command return here and do it again until the L number has counted down to zero then return to the next line down".
    P is just the label used on Haas, Fanuc uses O I think.
    M97 is an internal subroutine call to an extension (subroutine) on the bottom of the program doing the calling.
    M98 is an external subprogram call to a completely separate program.
    Aug 2005
    578
    Ahhhh....
    Thanks, I'll go give that a try.
    Jul 2005
    12177
    Ahhhh....
    You can also call a subroutine from a subroutine; we need to do this on some of our lathe programs that use the barfeed. You can have the subroutine starting at N2000 tacked on below the M99 in the first subroutine and then you can call this either from the "O" program or from the "N1000" subroutine. When the L count is not present of course the subroutine returns to the line immediately below the M97 and only does the subroutine once.
    I have found sometimes that it is best to plot things on a piece of paper in a flow chart and describe to yourself what is going on; it can get confusing when you get past about 3 subroutines. But I have also found subroutines very useful because you can have shorter programs and you can have different tools using the same set of coordinates so if you need to edit you only have one place to change.
    Aug 2005
    578
    Geof
    That worked nicely. Thanks
    May 2006
    132
    just set the initial push for your starting position. then figure your part length and cutoff. if you use a toolsetting probe then adjust your z+ probe offset setting.
    then just put a g115 in your program.
    Apr 2007
    Easy Q codes
    I've recently had to work on our lathe for a bit, and I fought the bar feeder for a week. Always hitting the wrong Q code and sending it searching for a bar that doesn't exist...
    Here's what I found works best for the way we run the servo:
    G105 Q6 - use this after loading program and setting up everything else, punch in all numbers in the bar feed page. This will unload the feeder -- you still will have to manually remove anything in the chuck.
    next:
    G105 Q4 - use this next, it will sweep the tray, load a bar, measure it, then pushrod and end in V axis jog. His handle jog and bump the stock until it barely clears the jaws.
    finally:
    G105 Q2 - set jaw height: wil push out stock to spec. amt.
    and thats it for setup, you're ready to run.
    End of program should look like this:
    o0000
    G105 Q0;
    M01;
    M99;
    That will loop around until your length has been burned up, or max parts.
    Hope this helps.
    Sep 2007
    56
    5000 button pushes
    Some got to it before I did .
    Change the g30 at end of program with a g99 and it will run continuously.
    No need for macro's of subprograms and other subprograms. I generaly do my set up with the g30 in place and change to g99 when program works flawlessly.
    Swain
    Mar 2010
    bar feeder
    We are using this one . Hope it helps , as its going great with us (except for ****ty mondays LOL) .
    N1000
    N97 P100 L8 ( nos of bars )
    M30
    N100
    M97 P1 L9(QTY IN 1 BAR)
    G105Q6
    G105
    Aug 2009
    235
    I think the servo bar 300 just needs it's own forum. Seems like everyone has issues with this thing. I just had mine running yesterday after a couple of months not using it and I was trying to take bets on whether or not it would make it through the whole job without any problems. No one took the bet. First bar load, my old friend "alarm 452 servo bar gear motor time out" showed up.
  1. DIY hydro bar feeder ?
    By D.D.Machine in forum Uncategorised MetalWorking Machines
    Last Post: 08-31-2009, 03:58 PM
  2. auto feeder
    By Syphonics in forum Mechanical Calculations/Engineering Design
    Last Post: 12-20-2006, 04:14 PM
  3. Bar Feeder for Trak Lathe
    By SeaSchell in forum Uncategorised MetalWorking Machines
    Last Post: 09-20-2006, 06:34 PM
  4. Simple Bar Feeder
    By Jarwalcot in forum Uncategorised MetalWorking Machines
    Last Post: 02-24-2006, 08:10 PM
