584,879 active members*
5,311 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Can a workbee CNC can cut 1mm galvanized steel sheet?
    Wink Can a workbee CNC can cut 1mm galvanized steel sheet?
    Hi am a newbie to routing and I am about to receive my first cnc router next week. I wanted to cut aluminum sheets on this and it would be a lot helpful if the Workbee can cut Galvanized steel sheets. My router comes with a Makita RT0700C Router. So I need to cut some designs and can someone tell me whether it will damage my machine in anyway if I cut steel.? And any special router bits or any equipment I can use so I don't damage my machine so fast?
    Jul 2018
    6255
    Re: Can a workbee CNC can cut 1mm galvanized steel sheet?
    Hi Abhi - Unfortunately the workbee with a mikita won't cut steel. But you can try and show us the results. Peter
    If I change the router will it work, can you suggest me what to look for?
    Jul 2018
    6255
    Hi Abhi - If you want to machine aluminium and steel you need a mill not a router. Peter
  1. die lubricant for forming galvanized steel?
    By wddanie in forum Bending, Forging, Extrusion...
    Last Post: 10-01-2020, 09:55 PM
  2. steel, aluminium,galvanized sheet metal fiber cutitng machine
    By wklaserliu in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-15-2016, 04:26 AM
  3. punching 2mm thick galvanized steel?
    By Volkhard in forum MetalWork Discussion
    Last Post: 02-23-2015, 01:39 AM
  4. Replies: 4
    Last Post: 07-03-2013, 04:08 PM
  5. RFQ: Sheet of steel
    By samualt in forum Employment Opportunity
    Last Post: 05-29-2006, 10:00 AM
