585,760 active members*
3,844 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > UCCNC Control Software > High Precision Automatic Tool Sensor Cnc Z Axis, How to wire to UB1 Controller UCCNC
Results 1 to 6 of 6
    Mar 2020
    60
    hello,
    Looking for help to Setup 4 wire automatic tool sensor to UB1. I seen people on Youtube with it setup on UB1, UCCNC Software. Didn't show how it was setup/connected.
    The only wiring i found was on google.
    Not sure if it apply to this probe, or perhaps they the same.
    Would appreciate all feedback
    thanks
    User avatar
    lloxley016
    Mar 2012
    34
    Re: High Precision Automatic Tool Sensor Cnc Z Axis, How to wire to UB1 Controller UC
    Hi, gotten this to work ? I use this one quite similar, just with chip blowoff.
    Mar 2020
    60
    Smile Re: High Precision Automatic Tool Sensor Cnc Z Axis, How to wire to UB1 Controller UC
    Ok. would share how did you wire it up... draw diagram.
    right now hive mines working, but only the yellow/green on X105 and 0V Pin/5 and I/O Port1, And work perfect. But that it can also be connected E-stop too.
    So when it go to far down, it trigger E-stop and the probing will stop. project your bit....
    I also found other documents from other forum, there they successfully set the up. but didn't show how they wire it. so sad..
    anyway i'll doing my research on this project.
    Mar 2012
    34
    Hi, what i did is that i just connected the override limit to the pins, and then i have connected that pin to reset in UCCNC, i belive it's code 152 on pin setup
    Sent fra min SM-G975F via Tapatalk
    Mar 2020
    60
    Hi
    Here is picture of UB1., Can you mark what you are talking about. "" just connected the override limit to the pins, and then i have connected that pin to reset in UCCNC ""
    UB1 doesn't hive reset pin., You talking E-stop
    Sep 2014
    28
    Did this configuration work for you?:
    "Yellow wire / => assuming it's ( Probe Single )
    Green Wire /=> assuming it's ( Probe Return Single )
    Red wire /=> 24v + Resistor 2k 1w
    Black wire /=> Either ( COM- ) or ( 0V ) Or Connect Green wire to ( COM-) + resistor"
    Did you connect the overtravel circuit to the OSSD safety circuit on the UB1?
  1. Replies: 0
    Last Post: 06-24-2020, 09:25 AM
  2. Replies: 1
    Last Post: 01-01-2020, 12:15 AM
  3. Automatic Tool Height Sensor input to KFLOP
    By amitkumar171 in forum Dynomotion/Kflop/Kanalog
    Last Post: 04-03-2018, 11:44 PM
  4. How to wire Active High proximity sensor to kflop JP7
    Last Post: 02-19-2018, 05:55 PM
  5. High precision 4 and 5 axis shop.
    By Vsmfg in forum RFQ (Request for Quote)
    Last Post: 04-27-2011, 10:31 PM
