586,000 active members*
4,861 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Huangyang VFD doesn't seem to want to use VI input
    Apr 2004
    475
    Model of the VFD is an HY02d223b I think, picking from the options in the manual. Running a 24K 2.2kw spindle, air cooled.
    I am running a uc100 controller (via UCCNC) with a c35 BOB and a C41rev3 PWM board from cnc4pc.
    After dropping the project for a number of years, a router rebuild of an ancient camtech (1995!), my big machine's spindle died and I have some time on my hands and have promised to sell this older machine to an ex-employee but hadn't gotten it to 100%
    I am currently trying to control the motor speed.
    After reading and taking Mactec54's advice of using a relay for the motor control and deciphering cnc4pc's barely implied hints in the c41 manual, I have the on / off working. Speed control, not so much.
    UCCNC is set at min speed .001 and max speed at 24K rpm. PWM Hz at 300 and 0-100% range.
    I have tried most everything I can think of and have confirmed that UCCNC is using the correct pin for the PWM and the output of the C41 does seem to work as I have the proper voltages across the ACM (multimeter's -) and VI (multimeter +) connections on the VFD.
    The VFD has been reset and parameters confirmed as per the big huanyang thread but that changed nothing.
    I'm using min speed as 200hz / 12000 RPM and max at full 400 hz / 24000rpm due to the air cooled spindle.
    If I set the VFD to external control on PD002=1 (and PD070 at 0 for 0-10v) I get only the minimum 12K RPM and changes in the VI voltage do nothing.
    If I set the VFD to PD070=1 and PD001=0, then I have the full range of 12K-24K RPM from the onboard pot
    If I set the VFD to PD071=0 I have an odd range of 12K to 18K rpm from the onboard pot
    (I suspect that is because PD073 is set to 200 and PD072 is set to 400 and the 5V the onboard pot is putting out is in the middle of that new range......I have seen Mactec54 recommend PD073 set to the same speed as minimum hz but that doesn't put 0v at 0rpm as one might expect.....it works if you have the same settings in UCCNC though.)
    I'm at a loss of what I am getting wrong here but I'm done for the night trying to figure it out.
    Other settings are per Mactec54's posts and I have tried both PD044 at values 1 and 2.
    Apr 2004
    475
    Re: Huangyang VFD doesn't seem to want to use VI input
    Figured I would reread the big huanyang thread......saw the words "might be a jumper" and fixed the issue.
    I DID move back to PD073 set to 0 and PD072 set to 400 with the same settings in UCCNC in RPM. I get if you had a regular pot it would make sense.....best in my mind to leave the CNC control have the full range to work with and just set the limits you need for these spindles on the VFD. IE I can program 8000rpm but the spindle min is 12000 rpm.
    Good, hours of time wasted on that.
    15362
    Quote Originally Posted by gfacer View Post
    Yes when you move from KeyPad to remote J1 has to be changed that is in most of my posts, it is usually in the Parameter lists I post so hard to miss this J1 jumper
    Mactec54
    15362
    This Post tell me you are still in Pot control 0-5v J1 needs to be changed
    PD044 is a Parameter that does not need to be changed the Default works fine that is why I don't list it as one that needs to be changed
    Mactec54
  1. Huangyang 2.2kw VFD pd177-180 Errors
    By justinwol in forum Phase Converters
    Last Post: 09-23-2021, 12:30 AM
  2. Breakout board input doesn't seem to switch when set to "Home"
    By johnnyt74 in forum LinuxCNC (formerly EMC2)
    Last Post: 03-28-2017, 08:01 AM
  3. Where can I get a manual for Huangyang 2.2 KW
    By futureform in forum Spindles / VFD
    Last Post: 09-07-2016, 11:31 PM
  4. Huangyang vfd HY07D543B 7.5 kw
    By BigDadyD in forum Phase Converters
    Last Post: 08-27-2016, 05:53 AM
  5. Actual settings for Huangyang 2.2 kw VFD
    By ajfoxy in forum Australia, New Zealand Club House
    Last Post: 07-31-2014, 04:35 AM
