I am having trouble just creating a basic post for the morbidelli u26. Its files are the .pgm I understand how to convert them problem is the post processor I use doesnt make the programs correctly. I have attached a simple 10 inch by 10 inch work piece with 5 inch circle cut in the middle as of how I would write it on the machine. Any one able to make a simple post that can do this exact same thing without adding all the other stuff to a program
H is the header
DX is max length DY is max width and DZ is max thickness
g0 starts router
g1 moves to next point
g2 clockwise arc
g3 counter-clockwise arc
uses an I and a J to calculate the arc
v is the feed rate
s is the spindle speed
t is the tool
AB is the field its ran on
DEF is the tool data stored on the machine
this machine has a set zero for x and y top left corner is always 0,0 or vice vs. for a mirror on other field DC (top right corner)
does not need any rapid traverse codes its built into the machine basically when a program comes to an end it stops and basically just moves the z back to a safe z but no special code for that doesnt need any special commands for safe z's
Any help would be awesome looks like it should be simple as compared to some of the other posts.
