585,982 active members*
4,648 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > PlanetCNC > Gantry Square two motors für y axis.
Results 1 to 9 of 9
    Nov 2015
    260
    Hello.
    I would like to use Gantry Square.
    I need a guide to configuration. Please all steps.
    My machine has 2 motors for Y. Two limit switches are mounted and connected.
    Thank you in advance.
    Daniel
    Feb 2011
    138
    Re: Gantry Square two motors für y axis.
    I have two motors for Y axes and limit switches on both axes, what you want to know?
    Nov 2015
    260
    I don't know what to set in the settings. That is not in the instruction manual.
    Feb 2011
    138
    I have done werry simple: settings-motors- : 1-x 2-y 3-z 4-y, just pay attention which direction motors turning!
    Limit switches I have mecanical connected: 1-x 2-y 3-z and lower in same panel: limit pin "reverse" (regarding electrical wiering switches) 1, 2, 3, 4, because I have it on both y axes, so 8 total.
    Just take a look to MK3 manual from pages 20-25 and pick up desired wiering.
    ps
    be sure to output slave Y axe from MB
    Nov 2015
    260
    I think we get on wrong. Of course I have it in the settings. But for the Gantry Square function you have to set something else with axis U and V.
    Feb 2011
    138
    ok, misunderstud, I think you looking for explanation in this thread, there is a pdf of it.
    I have made my a year ago by hand and measuring with a little geometrie calc. My switches are not squere to table, so wont help much...
    Nov 2015
    260
    Ok, it's done. Got it.
    Mar 2017
    1312
    You managed to make it work?
    Nov 2015
    260
    Yes I have. It was a little confused because I hit the E-Stop while in Auto Square. If you then looked in the settingings, the axes were still set with U and V.
    And you cannot determine which axis is slave and which is master.
    Since I had to swap the ports, then it worked as it should.
    I am very happy with it. I measured two places that were 30cm apart. and have deviations of approx. 1-3 / 1000. And that with repeatability.
  1. Replies: 0
    Last Post: 09-24-2019, 06:14 AM
  2. Troubleshooting Slave Axis and Gantry square
    By Jakeller449 in forum DIY CNC Router Table Machines
    Last Post: 06-06-2019, 01:31 PM
  3. Making a slaved X Axis gantry perfectly square
    By TheBulk in forum DIY CNC Router Table Machines
    Last Post: 09-08-2011, 05:58 AM
  4. flying gantry: 4 motors/3 axis setup
    By nicanor76 in forum Uncategorised WoodWorking Machines
    Last Post: 04-13-2011, 07:24 PM
  5. Gantry/two motors per axis...how to configure
    By chozo in forum DIY CNC Router Table Machines
    Last Post: 08-28-2004, 02:50 AM
