585,971 active members*
4,059 visitors online*
Results 1 to 3 of 3
    Oct 2020
    Mori seiki sl25 lathe no x-
    We have a x- not moving all oth motion is good x+, z-, z+ but no x-. We've verified limit and prox on x are working correctly. We've swapped servo amps x for y and no change. Fuses and breakes seem all good.... ??? Any suggestions would be greatful?
    Re: Mori seiki sl25 lathe no x-
    Seems it's acting like you had an over travel in X-. Maybe even a hard over travel. Moving the carriage X+ and hitting RESET should fix a soft over travel. Some Mori machines have a different procedure for getting out of a Hard over travel, including an extra button to push. Have to look in the manuals for that one.
    Sorry it's all I can think of. Again... acting just like it had an over travel in X-.
    Oct 2020
    Quote Originally Posted by the_gentlegiant View Post
    Thanks! We hv verified that and unfortunately it doesnt seem to be the problem. We will keep trying.
  1. Mori seiki sl25 siemens 820t
    By Reza59 in forum Mori Seiki lathes
    Last Post: 08-02-2020, 12:51 PM
  2. Parameter PCM TORNO MORI SEIKI SL25 FANUC 10T
    By ironpablo in forum Fanuc
    Last Post: 11-04-2019, 10:12 PM
  3. Mori SL25 w/ Fanuc 16T
    By emexcee380 in forum Mori Seiki lathes
    Last Post: 08-20-2012, 12:51 PM
  4. Mori Seiki SL25-M
    By Rennsteig in forum Fanuc
    Last Post: 10-05-2011, 11:22 PM
  5. Mori Seiki SL25
    By KaesynCAM_Tech in forum Mori Seiki lathes
    Last Post: 10-07-2008, 05:07 PM
