585,930 active members*
4,426 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Too many consecutive non motion blocks error
Results 1 to 7 of 7
    Oct 2020
    5
    I have a perplexing issue.
    We had a brown out/power surge at our shop about a month ago due to lovely California rolling blackouts. My 4020 was running a DNC program at the time and my other machines were off. The surge fried the serial board in my slave computer and the machine is now throwing a "Too many consecutive non motion blocks" error at random times during long run DNC programs.
    That error is usually reserved for 16 lines or more of code with no movement but in this case it's repeating the same movement code causing the error and the machine to stop. (see pic)
    I have already replaced the serial board which restored comms with all the machines but the 4020 is the only one throwing the error. I built a new cable thinking it got fried but the problem did not resolve.
    My DNC software shows the same string of code so I thought it was damaged. After uninstall, reload, and test the problem was still there. I also swapped the slave with another that we use in our other building but still no resolution.
    I found a reference on another forum that said if the post processor was modified so a (note) appeared on every line it would solve the problem but that did not work either.
    I'm now thinking that the comm board on the machine was fried too and is sending a bad signal back to the slave when it wants more code.
    I can't find any information about this happening to others so I thought I'd throw it out here.
    Thordo
    Aug 2009
    1573
    Re: Too many consecutive non motion blocks error
    ...this is a wild guess but, may be worth checking. Shut down the machine totally for 10-15mins and check the Backup Battery voltage. I have seen the battery cause comm problems before
    Oct 2020
    5
    Battery is brand new but it was bought on Amazon so it could have been a cheap knockoff... Or the power surge fried it. Will do a voltage test.
    THANKS!!
    Oct 2020
    5
    The battery is good 3.2 volts. DANG IT!! Would have been nice to be a $5 fix. Will keep looking.
    Aug 2009
    1573
    ...one other thing you might try because of possible corruption of memory after power failure.
    https://www.fadalcnc.com/media/pdf/Z..._Procedure.pdf
    If you have the DATC type tool changer...Step 3 is a little different before you Zero the Memory
    Oct 2020
    5
    I forgot that in the OP. Already tried clearing the memory. No dice.
    Oct 2020
    5
    In doing more research. It has a PCB-0363 CPU board that replaced the 1030-1 but it was discontinued by Fadal back in 2008 because it was buggy. It has never been an issue for me until now, if that's actually the problem. The bigger problem is NOBODY has that board. Calmotion says they MIGHT be able to repair my board or I can buy one of their control upgrades for $9K.
