585,919 active members*
3,924 visitors online*
IndustryArena Forum > CAM Software > SolidCAM for SolidWorks and SolidCAM for Inventor > Slowing down the final few cm of a cut in solidcam
    Jul 2015
    14
    Hi you all,
    I have something I would really like to implement but I do not find the setting in solidcam that would do what I want.
    Let me explain. When cutting wood materials and doing a deep cut like 18mm full slot 4F endmill depth of cut 18mm. Cutting the wood works just fine but as there are heavy forces at work on my vacuum table I would like to slow down the feed for the last 50-60mm as when the parts become smaller they tend to pop off the vacuum because of the high federate (4000mm/m).
    Is there any way to program this or set in solidcam to slow down the feed rate in the end to 10% of the normal federate. I have seen that you can set lead in lead out as a percentage of feed and speed. But that is set to the real lead out and doesn't effect the actual speed of the cut feed rate
    Thanks.
    Jul 2015
    14
    Anyone any idea?
  1. HELP - Slowing down the Traverse
    By shaffin in forum Bridgeport / Hardinge Mills
    Last Post: 03-15-2013, 01:25 AM
  2. slowing jog?
    By sped1530 in forum Mach Mill
    Last Post: 12-11-2012, 07:02 PM
  3. Slowing a spindle down
    By Fred Ming in forum DIY CNC Router Table Machines
    Last Post: 11-25-2009, 06:58 PM
  4. Slowing down of potentiometer
    By Mr-CNC in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-22-2009, 03:45 PM
  5. Slowing a motor
    By dighsx in forum CNC Machine Related Electronics
    Last Post: 02-24-2006, 12:44 PM
