584,879 active members*
5,150 visitors online*
Results 1 to 12 of 12
    Dec 2014
    21
    Looking for help making an mdf printing jig
    Good evening cnc zone long time no see.
    I have a massive amount of keyrings I need to print but I have to make them one at a time so I need a pressing jig made up if possible?
    The jig will be larger than a4 so I can print my designs in a set layout in a4 and place over the top of the jig to produce 15 in one go.
    Material and sizing.
    Mdf sheet 9” x 12.5” depth not more than 1” (if possible)
    15 milled out recesses to be spaced equally 20mm apart
    Recesses need to be 3” wide x 1.5” high and 1.29mm deep
    I passed on my cnc machine a long time ago so it’s Sod’s law I now need it.
    Any help would be greatly appreciated.
    Many thanks.
    Paul.
    Apr 2020
    29
    Re: Looking for help making an mdf printing jig
    Do you have drawings?
    Dec 2014
    21
    I don’t but I can make something up later.
    Apr 2020
    29
    PM if you have updated files. I can make the quote and produce it to you.
    Dec 2014
    21
    If this makes sense??
    An MDF base 340x250x20.
    The red outline needs to be exactly A4 size and roughly 1mm deep to mark the outline of an A4 sheet so i can align the printed A4 sheet with the recesses,
    Each Blue area is where a keyring will be inserted so cut out to 1.2mm depth.
    Please let me know if you cant see the above image.
    Many thanks
    Paul.
    1206
    The machine that can cut a sharp internal 90 degree corner would be a game changer.You either have to chisel the radius away by hand or accept a "dogbone" relief.I'm not sure where in the UK you would find 20mm MDF as most stockists hold 18mm or 25mm as the next step up.One or two seem to supply 22mm-is the thickness critical?Once you have the material,a piece of this size is a pretty minor job and shouldn't cost much.
    Dec 2014
    21
    Quote Originally Posted by routalot View Post
    It doesnt have to be 90degrees its just a box for the example
    MDF 20mm is also a rough guess i dont buy it so i doint know the sizes available so 18mm or 25mm is fine.
    Also I can't edit my origninal posts to add the above.
    Dec 2014
    21
    Anyone?
    1206
    Whats your location?I may be able to help if you are in the UK.
    Dec 2014
    21
    Devon U.K.
    1206
    I did send a PM.
    Nov 2021
    4
    SO this is over? IF you need still, give me file and i can try.
    [email protected]
  1. UV Printing - UV LED goes out partway through Printing
    By KenR60 in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 01-09-2020, 05:52 PM
  2. UV printing machine, T-shirt printing machine
    By laser111 in forum News Announcements
    Last Post: 10-12-2015, 09:25 AM
  3. 3D Printing Live! Joining the ranks of the international 3D printing conferences
    By cncadmin in forum 3D Printer / 3D Scanner Discussion
    Last Post: 10-15-2013, 09:20 PM
  4. Printing
    By kenlambert in forum BobCad-Cam
    Last Post: 03-31-2004, 01:22 AM
