585,752 active members*
3,924 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > What files do I neeed to copy to keep V32 the same on 2 computers?
    Aug 2008
    93
    I want to keep both of my seats synchronized as far as all the settings. I can copy the post processor easy enough, but what other files do I need?
    Dec 2008
    4548
    Re: What files do I neeed to copy to keep V32 the same on 2 computers?
    You can go to file- user profile...
    There they have buttons to save and load "layouts", which is the GUI...
    For other things like "Tools", you will need to use the specific dialogues to save and export and import the various libraries that you may customize...
    There are a few things you will consider. Tools. Adapters. Holders. Threads. Materials. DMS setups. Cutting conditions. The machine setup can be copied from the folder "C:\BobCAD-CAM Data\BobCAD-CAM V32\MachSim"
    Did I miss anything?
    You might just copy the "C:\BobCAD-CAM Data\BobCAD-CAM V32" folder to the new machine, which "SHOULD" hold the various files that have all that stuff. The "SHOULD" is key there. They used to keep stuff in the registry too....
    May want to ask them. They may have a definitive, easier way.
    Aug 2008
    93
    Quote Originally Posted by BurrMan View Post
    Thank You, I do not have a support plan right now so I do not know if they will answer me.
    Randy
    Dec 2008
    4548
    Quote Originally Posted by BNR_RANDY View Post
    Randy
    The data folder copy should cover it, along with the user profile save and load
  1. How to copy V26 files to V30?
    By Podunk in forum BobCad-Cam
    Last Post: 04-29-2019, 01:09 AM
  2. biesse rover 322 can't copy files
    By azizcom83 in forum Commercial CNC Wood Routers
    Last Post: 11-19-2017, 09:06 PM
  3. Which files to copy?
    By snkdriver in forum Mastercam
    Last Post: 01-14-2013, 07:07 PM
  4. Files to copy accross
    By Prboz in forum Mach Mill
    Last Post: 02-13-2007, 03:21 PM
