585,722 active members*
4,029 visitors online*
    Oct 2018
    19
    Switching over to UCCNC
    I'm all Mach'ed out....I ordered a 300 and a UB1...I am going through the software and in ESS/Mach setup I can select Step/Dir, Quad and AB for servo control...can you do that in UCCNC as I haven't found that setting anywhere...Thanks!
    35538
    Re: Switching over to UCCNC
    I've never used an ESS, so I don't know what those settings do, but UCCNC, like Mach3, is a Step/Direction control. What do those settings do?
    Oct 2018
    19
    Hey Ger...reminds me I need a screen set...our big machines use Quad...its a shorter pulse if I get it all right on the corner of the signal pulse itself...1/4 the wave...also there is CW, CCW A+B+ and a few other besides Step and Direction....if UCCNC is S/D only I am ok with that just wanted to make sure I wasn't missing something...I do like Quad as it can be a bit more resistant to noise as I said but S/D will be fine.
    35538
    I believe those are ESS specific features.
    With UCCNC, I believe the pulse width is dependent on the step frequency.
    The UB1 does give you some wiring options....
  1. Need Help switching to g91
    By bcnu in forum BobCad-Cam
    Last Post: 04-01-2016, 02:36 PM
  2. Switching DC pos or neg?
    By Skiroy in forum CNC Machine Related Electronics
    Last Post: 08-03-2011, 02:29 AM
  3. switching x and y
    By ataxy in forum Mastercam
    Last Post: 09-24-2009, 12:01 AM
  4. Switching from one computer to another.
    By Wahoo4 in forum BobCad-Cam
    Last Post: 12-27-2007, 03:32 AM
  5. Pwm switching
    By miro in forum Gecko Drives
    Last Post: 01-23-2007, 10:22 PM
