585,687 active members*
4,587 visitors online*
Results 1 to 6 of 6
    Sep 2009
    12
    Guard door - Probe Heidenhain
    Hello,
    I have a question about the touch probe,
    iTNC530
    machine brand YCM, Nsv and other type.
    here is the problem, we have recently stated too lock the guard doors and the operator cant use the probe with doors open.
    but one machine can do this ( Matec).
    so i was thinking, is this some way to fix this
    with the security still working as it sopouse to .
    sorry for my bad english.
    Mr Larsson from Sweden
    Mar 2016
    323
    Re: Guard door - Probe Heidenhin
    check the PLC status in the tool table (set of the 0 and 1 numbers for each tool) the difference may be there or in the MP's, but i'm not sure which one is it.
    Sep 2009
    12
    thanks steryd
    i will check that tomoroow
    Sep 2009
    12
    re: Guard door - Probe Heidenhain
    update
    we did check and it was the same in all machines ?
    that didnt work
    Re: Guard door - Probe Heidenhain
    Quote Originally Posted by skucku99 View Post
    Hello,
    iTNC530
    Find the related CNC parameter of the door guard sensor, try to disable by changing the parameter, or just disable the door guard sensor itself.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Sep 2009
    12
    thank you for replying.
    well its easy to cutout the guard door but we will not go back to that
    thats what we have been doing for many years and its ilegal hehehe.
    trying to do the right thing here
  1. Heidenhain TS-112 touch probe
    By rooj65 in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 12-24-2017, 10:01 AM
  2. Heidenhain kt 130 probe
    By MBViklund in forum Novakon
    Last Post: 09-29-2015, 09:37 AM
  3. Need help on wiring E-Stop and Door Guard
    By Mcyoda in forum CNC Machine Related Electronics
    Last Post: 07-19-2009, 05:28 PM
  4. Gas struts forces for Emco guard door.
    By Adee in forum Benchtop Machines
    Last Post: 10-04-2007, 11:51 AM
