543,651 active members*
2,210 visitors online*
IndustryArena Forum > Other Machines > General Other Machine Discussion > PC Interface Board Recommendation
Results 1 to 2 of 2
    Registered
    Aug 2014
    Hello,
    I recently acquired an Systro 4 axis CNC table with DC servo system (ISEL PVD servo driver unit, SKC DH series servo motors). The servo driver unit has a 50 pin connector with a pin for each of the axis described below:
    Index +
    Index -
    Track A+
    Track A-
    Track B+
    Track B-
    Analog Input (Control voltage)
    Reference switch pin
    limit switch positive
    limit switch negative
    (attached is full pinout)
    I am new to CNC machines and from the research I have done so far, I may be able to get a USB interface board and use this setup with Mach 3 software. However, when I look at the specs of some Mach 3 USB interface boards, I can't tell if they can be used with my system or not because I don't know what the pin names in my system do (ie, index pins vs track A/B pins).
    I am looking for some recommendation as to which mach 3 USB interface board would work with my system and also some help to understand what the index (+/-) and Track A/B pins do. Any help is appreciated.
    Thank you.
    Member
    Oct 2020
    8
    Re: PC Interface Board Recommendation
    Connection to the computer is galvanically isolated, so that damage to the computer from the card is not possible. The card is controlled in a simple way using Turbo Pascal, QBasic, Visual Basic, Delphi, C++ (to use with MS-DOS, Win3.11, Win95, 98, ME, NT, XP, 2000). These procedures are pre-programmed and are provided along with a number of test and example programs on the diskette supplied. The card itself has 16 galvanically isolated digital connections, which can be freely chosen as either inputs or outputs (eg. 6 inputs and 10 outputs) according to how they are set up by the user. Furthermore, the card has 9 analogue outputs, of which one is high precision, and 4 analogue inputs. If this capacity is not sufficient for a particular application then up to 4 cards can be connected together (1 master and 3 slaves), such that an enormous potential exists. The card can be used with many of our other kits such as : K6714 16 channel relay card, K8023 10-channel 2-wire remote control.
    Features
    galvanically isolated from computer
    9 analogue outputs, of which one is high precision and 4 analogue inputs
    a simple way of controlling using Turbo Pascal, Turbo C, Qbasic, Visual Basic
    printer bypass connector on board
    simple connection with printer port
  1. Breakout board recommendation
    By men8ifr in forum Benchtop Machines
    Last Post: 10-23-2018, 03:21 AM
  2. Replies: 5
    Last Post: 04-29-2017, 10:09 PM
  3. USB I/O Interface Board
    By Tony T in forum Tormach Personal CNC Mill
    Last Post: 01-30-2017, 11:16 AM
  4. BREAKOUT BOARD INTERFACE BUFFER BOARD
    By deslee in forum Servo Motors / Drives
    Last Post: 08-17-2014, 07:32 PM
  5. Interface board Rodgers board/ Romaxx Encoder Interface.
    By Ark1 in forum Wood Lathes / Mills
    Last Post: 03-23-2013, 10:57 PM
