Hi All - Adhesives are very good for many things. So I'll show here that a bonded rail connection is much stronger then a bolted connection. Loctite describe 290 as med/high strength but don't publish its shear strength. Their other med strength threadlockers have a shear strength of 10MPa and their high strength is 20MPa. I use epoxy a lot and it varies from 20-30MPa and you can get 40MPa if needed. So if you use a 20mm rail (some are flat bottomed some have two lands, I'll use the two landed version as it has less surface area) So a rail can slip sideways under load (shear loaded) it can be pulled upwards or compressed. Tension and compression are usually not an issue. So its shear we are interested in. If you use an M6x1.0 C12.9 this provides a friction capacity of 359kgf per bolt if you use a friction co-efficient of 0.25... If you use a medium strength loctite to hold it on the adhesive provides a 924kgf resistance to slipping. So the adhesive is worthwhile to keep things in place... Peter
