586,009 active members*
4,868 visitors online*
IndustryArena Forum > CAM Software > MadCAM > None of the 2D Curve Options have any effect
    Dec 2011
    97
    I am following a 2D curve and the tool path location is at the cutter center instead of the tip even though the Cutter Tip option is shown in 2D Options. Also changing the Depth option seems to have no effect on the generated tool path.
    Re: None of the 2D Curve Options have any effect
    Hi MitchB,
    Just a guess- if your curve is open there is no way for Madcam to know inside from outside.
    regards, Maarten
    Dec 2011
    97
    Quote Originally Posted by Maarten Visser View Post
    Hi MitchB,
    regards, Maarten
    Thanks, but I am using "Along Curves" so the side shouldn't matter. I am seeing a problem with the depth of cut - I see the same issue when I test with a circle. The curve path is treated as the cutter center by the post processor instead of the cutter tip even though "Cutter Tip" is selected in 2D options. So the cut is deeper than I expect.
  1. Curve Side on profiling operation - "on curve"
    By Gsmcelwee in forum MadCAM
    Last Post: 09-11-2014, 10:20 AM
  2. M3 and M5 codes having no effect
    By JBPlastic in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-06-2011, 12:15 AM
  3. Smoothing effect
    By bundysax in forum Mastercam
    Last Post: 03-13-2011, 12:34 AM
  4. What am I getting this effect?...
    By cnczoner in forum MetalWork Discussion
    Last Post: 02-02-2008, 06:31 AM
  5. guitar effect
    By xfidelity in forum Hobby Discussion
    Last Post: 06-26-2007, 12:19 PM
