585,975 active members*
5,082 visitors online*
Results 1 to 6 of 6
    Apr 2020
    19
    SBR rails or Linear Rails ?
    Your Input would really be appreciated.
    My current gantry uses electrical din rails with roller bearings for X movement. I am looking to replace them with either SBR15 (or other recommended size) rails and corresponding blocks, or linear rails and their corresponding blocks. Regardless of which is the best, the chosen ones will be mounted vertically on the face of the gantry. The gantry itself is a square birch plywood box; the span is 48” wide. The router that the chosen rails will support is a DW611 mounted using 3/4” birch plywood, i.e., Not heavy as lead, but not exactly light either. Biggest concern is stress on the bearings from either block type. I am attaching a pic of my current gantry setup.
    With your recommendations, I would appreciate your thoughts on size or heft of the rail and blocks. Enjoy my CNC, but need to get some play out of it.
    Thank you in advance.
    Bobby
    Jul 2018
    6337
    Re: SBR rails or Linear Rails ?
    Hi Bobby - For the type of machine you have round or square rails are fine. I like 20mm as it's a good physical size. They take something like 3 tonne from memory so you won;t undersize them. Round rails are about half the cost of square. Round supported rails work well with timber structures as they have a nice big contact area wheres the square rails have a small contact area and if you do the bolts up hard it will crush the timber. I think I'd go round as it fits with your machine type better. The performance increase to cost benefit would not be realised if squares where used. If space is tight then the square 15mm is the go. Regards Peter
    1224
    While you are improving your machine,it might be a good time to add a diagonal brace to eliminate any possibility of flexing between your Z axis and the router.
    Jul 2018
    6337
    Routalot means a brace like attached - Peter
    Apr 2020
    19
    Thank y’all for the quick responses. Will do a ???? on pricing / sizings. As far as the router mount brace is concerned, thanks for pointing that out. Ironically, I saw that brace pointed out in a YouTube last night. Great minds run the same path .... y’all’s not mine!
    Again, Thanks..
    Bobby
    Mar 2021
    solved my issue blogger at : https://mymusicgoals.com/
  1. Replies: 17
    Last Post: 08-16-2015, 06:48 AM
  2. Linear Carraige or Linear Motion Round Support Rails
    By newpatch in forum DIY CNC Router Table Machines
    Last Post: 03-09-2012, 12:36 AM
  3. Replies: 1
    Last Post: 05-04-2011, 05:16 PM
  4. Thomson Bars, V-Rails, or Linear Rails
    By Chuck_M in forum Linear and Rotary Motion
    Last Post: 12-18-2009, 09:39 AM
