585,883 active members*
5,276 visitors online*
    bridgeport vmc800/22 BMDC not runnig
    Hi everyone
    i try to fix stopped machine after some years that not working, is a bridgeport VMC800 /22
    when i power up and execute run.exe the control software appear the message to said BMDC not running after this i go to startup
    the B3T.exe this is a test control of the cnc, i see some physical testing like bmdc board and other things like memory, uart and others
    but Analog test is not passing the message said, expected ADC X axis value is 0 ADC value 6, and other testing said
    ADC or DAC error!
    expected ADC X axis value is 80 ADC value 7F
    i need some help about this issue
    thank you very much
    Note: upload some images for more details of this issue
    Jan 2018
    44
    Re: bridgeport vmc800/22 BMDC not runnig
    I don't know if you ever got this figured out but I had the same issue. In quite a few different threads, machinetek suggests removing the BMDC board and cleaning all of the contacts with a pencil eraser. He also suggests moving it to a different ISA slot if possible. I did this and it worked straight away.
    Give her a go and let me know what happens. It sucks to read through threads that have no resolution!
  1. Bridgeport VMC800 DX-32 File Transfer Issue
    By cap2031 in forum DNC Problems and Solutions
    Last Post: 03-14-2020, 03:53 AM
  2. Bridgeport vmc800/22; DX32 issue
    By rrperformance in forum Milling
    Last Post: 08-15-2019, 04:14 PM
  3. Bridgeport VMC800/22 Excessive air from spindle
    By jamesgates1000 in forum Bridgeport / Hardinge Mills
    Last Post: 12-06-2018, 01:40 PM
  4. BridgePort VMC800 Spindle Orient Issue
    By StickShifter in forum Bridgeport / Hardinge Mills
    Last Post: 04-17-2016, 03:00 AM
  5. 1997 Bridgeport VMC800 DX32
    By pbrtoolmaker in forum Bridgeport / Hardinge Mills
    Last Post: 10-26-2008, 02:39 PM
