585,971 active members*
3,986 visitors online*
Results 1 to 3 of 3
    Jan 2016
    69
    Size air source for plasma CNC
    Hello, I need advice on how to size my compressed air source for a plasma CNC table. My plasma unit is Hypertherm Powermax 45XP. The Hypertherm book lists the recommended air inlet as 400 cfh @85psi.
    My current air compressor is a California Air Tools 10020 2.0 HP 10gal that can deliver 5.30 CFM (or about 320cfh) @90psi. I like it very much because it is quiet, oil-free, and runs off 120 V. This is not a production environment --- I am a hobbyist, making small parts in my suburban garage. So space, quiet operation, and 120V are constraints (I do have 240V for the plasma).
    Will my current compressor be enough? If not, can I add an air tank of 20+ gals and fill that up first, then run the CNC off it? I'd hate to have to sell my almost new, lightly used compressor at a loss to buy a slightly bigger unit, but I am determined to do what needs to be done to have an operational system. After all, I did not cheapen out when I bought the Avid Pro setup and Hypertherm plasma source.
    Thank you for all the advice.
    May 2015
    686
    Re: Size air source for plasma CNC
    There are not really any shortcuts. In reality, you need some headroom so you don't have a high duty cycle on the compressor, hot air leading to increased water in the air, marginal air pressure etc that will cause more problems. My guess would be that you should be looking at a 500 cfm compressor
    Rod Webster
    www.vehiclemods.net.au
    Jan 2016
    69
    Got it. Just placed an order for a Quincy 3.5HP 60Gal unit ( Model: Q13160VQ ) that should deliver 12.8CFM, so it should have headroom above my needs of 7-8 cfm.
    It's a 240 V unit, so will have to have an outlet drawn.
  1. Why plasma power source is not starting when the CNC is in plasma mode?
    By Steel Tailor in forum Other Machine Topics
    Last Post: 01-22-2015, 04:04 AM
  2. lathe tooling size and source recomendation
    By AchillesGr in forum Uncategorised MetalWorking Machines
    Last Post: 08-07-2011, 09:54 PM
  3. desktop size CNC (is there any open source design?)
    By error404 in forum Open Source CNC Machine Designs
    Last Post: 02-22-2011, 09:59 PM
  4. Drawing Size and Cut Size Differ - Plasma
    By ADucci in forum LinuxCNC (formerly EMC2)
    Last Post: 10-05-2007, 10:52 AM
  5. Drawing Size and Cut Size Differ - Plasma
    By ADucci in forum Mach Plasma / Laser
    Last Post: 10-04-2007, 02:49 PM
