586,011 active members*
4,310 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > 4th axis and small diameter parts - looking for ideas
Results 1 to 11 of 11
    Jan 2007
    311
    I need to drill some small holes (.063") into the wrench flats on the head of a handful (16) of 3/8 bolts (.375" dia x 1..250) long. The problem is each part has 2 holes in the end, on two of the wrench flats 60 deg apart
    I've got a 4th axis with a 4" chuck mounted to it but I can't get down near enough to the parts for a small drill-chuck. The chuck jaws are too short to allow the part to be held away from the body far enough for clearance of the drill chuck/holders
    I'm thinking of using one of the weldon style 3/8 endmill holders I have but the threads are too small and it's sloppy fit, the 3/8 er11 collet chuck will work but again it's too big around to get in there with a small center-drill etc.
    Anyone have some suggestions without a ton of fabricating ???
    M
    Jun 2006
    3063
    Re: 4th axis and small diameter parts - looking for ideas
    Can you use a 5C or some other form of collet in your 4t axis instead? For a job count that small I'd be tempted to use a a 5C hex collet block like this one:
    https://www.shars.com/5c-collet-block-set
    Along with a collet stop to make the head location repeatable under the spindle.
    Dec 2013
    5717
    I would just thread the end of a piece of the largest bar stock you can fit in your chuck. Maybe taper the end for clearance if needed. Screw the bolt in and make holes.
    Jim Dawson
    Sandy, Oregon, USA
    Apr 2013
    1788
    I was running a job earlier today that is worse than your problem; you could use the same technique. I needed to cut 4 slots on the side of 0.125 diameter stock. To get sufficient clearance I mounted an ER16x20mm collet extension in an ER40 square collet block which I clamped in my vise. I only needed a few parts and it took a few minutes to setup and cut each piece.
    Jan 2007
    311
    Quote Originally Posted by MichaelHenry View Post
    Unfortunately the 4th is a faceplate with the chuck mounted to it, At one company I worked at we had a 5c 4th axis with a small end around the collet, that would work perfection for this
    I played tonight with mounting a er11 chuck into the 4th chuck but it didn't work out well (the 4th chuck isn't what it should be really)
    M
    Jan 2007
    311
    I think this might be the only temporary solution, there shouldn't be any forces trying to unscrew it. I'll need to re-index the stock to align the flats but hopefully it'll be quick
    M
    - - - Updated - - -
    I do need to invest in some 5c or even er32 collet blocks though
    M
    Apr 2013
    1788
    If you want to use your 4th axis rather than a collet block get an ER collet with MT2 shank (assuming that your 4th is like mine). Add and ER extension if that doesn't give enough clearance. I mostly leave a 5c collet chuck mounted on my 4th and that gives sufficient clearance except for the small work.
    Apr 2013
    1788
    I think that you'll find an ER40 collet block more useful than a 5c one. On most 5c collet blocks the closer makes it difficult to set a stop on the back side to position the collet chuck at a repeatable location in your vise plus you can't insert a long piece of stock through most 5c collet blocks.
    Nov 2007
    2151
    +1
    If I can get it to fit in a 5c fixture format "5c blocks, 5c chuck or 5c in 3-4 jaw chuck" I can literally have my way with it.
    If the part is real small and problems reaching features I move to an er 20 tts style holder.
    If strange shape or with thin places, I would move to a dedicated mandrel type fixture as Dawson mentions.
    Nov 2005
    157
    An albrecht sensitive drill might be perfect for that, though you feed these by hand via a knurled ring.
    Small enough to get close, and a 20mm stroke on the sliding shaft.
    https://cdn.webshopapp.com/shops/367...drill-chuc.jpg
    Jan 2007
    311
    Quote Originally Posted by kstrauss View Post
    True, but I have 5c collets as well as a couple of sets of ER32s, no ER40s
    M
  1. Any ideas why I keep having this problem? Small hole in my parts?
    By carphugger in forum Automation Technology Products
    Last Post: 11-15-2014, 05:07 PM
  2. Replies: 3
    Last Post: 01-10-2014, 06:22 PM
  3. Outside diameter perfect, insider diameter is too small
    By volkl_ac3 in forum Machines running Mach Software
    Last Post: 07-31-2012, 11:55 PM
  4. Questions -- Small CNC Router with VERY SMALL Work Area, Ideas?
    By Building in forum DIY CNC Router Table Machines
    Last Post: 02-03-2012, 11:36 PM
  5. Want to buy 3 axis cnc mill for small engine parts
    By Ironmancarbon in forum Want To Buy...Need help!
    Last Post: 11-07-2008, 04:24 PM
