584,863 active members*
5,010 visitors online*
Page 1 of 2 12
Results 1 to 20 of 22
    Oct 2005
    612
    Aussie gantry router build number 4
    I seem to be addicted to building these things. I'll let the photos show the progress.
    First set is the steel work for the base
    Attached Thumbnails Attached Thumbnails Base_1.jpg   Base_2.jpg   Base_3.jpg   Base_4.jpg
    cheers,
    Rod
    Perth, Western Australia
    Oct 2005
    612
    Next set a bit further along
    Attached Thumbnails Attached Thumbnails Gantry_side.jpg   Overhead_view_first assembled.jpg   SIde_view_first assembled.jpg   front_view_first assembled.jpg
    cheers,
    Rod
    Oct 2005
    612
    The Xylotex driver board in the making.
    Attached Thumbnails Attached Thumbnails driver panels.jpg   electronic_power_supply.jpg   electronics_1.jpg   electronics_2.jpg
    cheers,
    Rod
    Oct 2005
    612
    And getting a bit closer to being finished
    Attached Thumbnails Attached Thumbnails front view alomst completed.jpg   table.jpg   on trolley.jpg
    cheers,
    Rod
    Oct 2005
    612
    Now for some detail.
    It has a cutting envelope of 485mm by 485mm by 110mm and uses actuators on all three axes. A neat and quick way to build a machine.
    The cranked gantry is used to bring the weight back over the X axis linear bearings and also to shorten the table.
    The table has a push pull fastening system that uses grub screws to adjust the height of the table and socket head screws to hold it down. A quick adjustment with a dial gauge on Z axis got it within 2 thou and I hope to improve on that in a week or so after it all settles down.
    The table has a gap of 50mm between the sides to allow for side clamping.
    The gantry sides and panels for the driver board were cut on one of my earlier machines.
    I use die grinders on all my machines as I have found them to be more robust than a router. This one is a Milwaukee 1/4 inch variable speed.
    I am using 269 oz steppers and expect 3metres/min based on previous builds using this combination.
    I'll post back when it is finished.
    cheers,
    Rod
    May 2006
    2420
    I think you have forgotten something ?
    As per your own convention this latest beastie should have a name
    Very nice work btw, judging by the time you posted seems like you have been burning the midnight oil to get it going. Oh well you have shamed me back into action, I have done more talk on my machine than actual work lately, I think it is time to start doin stuff again.
    Cheers.
    Russell.
    Oct 2005
    612
    Hi Russell
    Good to see you are still into the CNC. I have to burn the midnight oil at the moment as I have parts for another two machines waiting to be built. It's all good fun.
    I didn't forget the name and if you go to post 2 you can see Rodot engraved in the gantry sides. I'm running out of names.
    Yeah lets see some action from you guys on the other side.
    cheers,
    Rod
    love the gantry design
    youve obviously took some time to come to a good plan and youve gathered some really nice gear to dress that baby with
    good show man
    Oct 2005
    612
    Thanks for the comments Dertsap.
    I run with a few ideas in my head and just try to build them better than the last one.
    cheers,
    Rod
    May 2006
    2420
    Quote Originally Posted by Rodm1954 View Post
    Heh, working on it, I gotta fix the first to make parts for the second, I'm sure you understand, lol
    Russell.
    Oct 2005
    612
    Russell,
    Sure do. We push it uphill in Oz with prices and availablity of parts. Only the very keen and patient finish a build.
    I start collecting parts three months ahead or else it sits partly completed for weeks while parts ship from disant shores.
    cheers,
    Rod
    May 2006
    2420
    We push it uphill and around the corner, as I mentioned in my router thread, encoders are holding me up now, I even looked at making my own, seems that I can't even get the optical pickups without buying a million of them (chair)
    I guess it makes us try a little harder, I am now planning to make my own servo drives, boards, components the whole thing, so the only thing I will have to import is the encoders and possibly future servos, though I am working on both of those.
    Russell.
    Jun 2003
    453
    That's a really nice looking machine there Rod. Where did you source the actuators from?
    Cheers
    Splint
    Oct 2005
    612
    Hi Splint,
    Good to hear from you. I got a pair of them off ebay and they were new so hopefully I will get a reasonable service life out of them. A fellow from Queensland got a pair as well and he is starting a similar build. It is an easy way to make a machine but I feel like I am cheating not having to allign linear rails and ballscrews amd make bearing blocks.
    cheers,
    Rod
    Oct 2005
    612
    I finished the machine today and had it running tonight. Rapids at 6m/min which was better than I exepected so pleased with that.
    Here is the finished product.
    Attached Thumbnails Attached Thumbnails Finished_front.jpg   Finished_side.jpg   Finished_side_2.jpg
    cheers,
    Rod
    Dec 2006
    277
    Hi Rod,
    Good to see it is finished. #4 Looks very nice too
    Bob
    Oct 2005
    612
    Thanks Bob
    cheers,
    Rod
    May 2006
    2420
    Nice work Rod, so at 6m/min does that mean its too fast for video ?
    Russell.
    May 2006
    1469
    Another great looking machine from the Rodm1954 factory.
    Greg
    May 2005
    405
    Great work. So do you now have a collection of machines or have you sold some of the others.
    Paul
Page 1 of 2 12
  1. Bobs Aussie ITEM Router Table Build
    By crocky in forum CNC Wood Router Project Log
    Last Post: 10-30-2016, 01:42 AM
  2. Another Aussie homebuilt router
    By Greolt in forum CNC Wood Router Project Log
    Last Post: 05-08-2010, 11:14 PM
  3. Router Build Help (Aussie)
    By twistedfuse in forum CNC Wood Router Project Log
    Last Post: 07-07-2008, 01:32 PM
  4. Another Aussie Router build
    By Matty Zee in forum CNC Wood Router Project Log
    Last Post: 05-05-2008, 10:19 PM
  5. Which Aussie wants to sell me a router table
    By Esmae in forum Australia, New Zealand Club House
    Last Post: 10-29-2006, 01:08 AM
