585,705 active members*
4,326 visitors online*
Results 1 to 20 of 20
    Sep 2008
    12
    Aluminium Machine Bed
    Hi
    I'm building another CNC machine and want to put an aluminium bed on it using something like 15180 extrusion. However, I cannot find a supplier anywhere in Australia and have tried to organise it through some Chinese suppliers but there are so many dodgy operations over there, I'm not confident in outlaying substantial dollars if I'm likely to get caught out.
    Does anyone have any ideas about RELIABLE suppliers of machine bed extrusion?
    Cheers
    Apr 2004
    5734
    Re: Aluminium Machine Bed
    What about starting with a solid piece of aluminum plate and cutting your own T-slots in it? That would be better than a series of pieces of aluminum extrusion lying next to each other.
    Andrew Werby
    Website
    Sep 2008
    12
    Quote Originally Posted by awerby View Post
    Solid plate is too expensive here and I've been caught out before with plate that is not completely flat. Cutting the T slots would be problematic too.
    Jan 2008
    1527
    What is the use case Geoff?
    I made up a T slot bed out of multiple extrusions in the past. Ended up being a pain because you don't want to cut straight onto it....
    Now I just use sacrificial MDF and much easier.
    MDF with T track in it?
    Sep 2008
    12
    Quote Originally Posted by pippin88 View Post
    This is the fourth CNC machine I've built. I want the T slot bed to make it easier to fix various jigs, including vacuum pucks, rotary axis, etc. The jigs incorporate their own spoilboards, so no danger of damaging the bed. I've been using mdf spoilboards for years, but, for this machine I want the t slot bed as the mdf bed is a pain with the jigs I use.
    Since posting this thread I have found a Chinese supplier who is said to be reliable and reasonably priced. Despite the slow shipping It may be worth the risk. Something to think about.
    Jul 2014
    13
    - - - Updated - - -
    MISUMI SHIPS TO AUSTRALIA , CLICK PICTURE ABOVE
    Sep 2008
    12
    Quote Originally Posted by Zvonkorp View Post
    - - - Updated - - -
    Hi Zvonkorp
    Yes I had a look at Mizumi but their shipping costs place them well outside the ballpark.
    I have found a supplier from China and have placed an order. Just have to play the waiting game now to see how it turns out.
    Thanks everyone for your ideas.
    Cheers
    Jan 2007
    626
    Who did you go with?
    I was looking at Ali extrusion a while ago and was overwelmed by the options and emails from suppliers.......
    Sep 2008
    12
    Quote Originally Posted by Sterob View Post
    I used Aliexpress and purchased from a store called "Dreamer Hunting Store".
    It may be that I'm dreaming and the deal could be a flop but it remains to be seen. I didn't just accept the price and shipping cost as per their listing but contacted them and negotiated a deal. If the deal is successful I'll let everyone know as they hava a lot of gear in that store. I'll also let you lknow if it fails.
    Cheers
    Sep 2020
    Thanks for sharing this information as I was looking for this and I already have Aluminum casting suppliers - https://rpplindustries.com/services/castings/
    Jun 2012
    I have found most Aliex sellers don't come down much unless you can bulk up your order, their freight is usually on the edge. Its too bad sellers don't have a logistics agent here for heavy stuff like bed plates.
    I have a design for 20x150mm(5mm thick) extrusion that I intended to make from 6061, but au has a big tariff from cn on aluminum extrusions. I could have got them made into a table kit with frame & fasteners.
    Talking to some local mills they would not make my design from 6061 as they could not guarantee the dimensional finish in the T-slots.
    Looking at 6106 alloy, its better than 6063 which most bed plates are made from. Startup costs are a lot higher from local suppliers.
    The bedplate is intended for small to medium sized machine, but it really depends how much frame support is under the plates & intended use as to the table size
    Jun 2013
    443
    I've just bought a T Slot cast iron bed out of China into NZ. Cost $2500 for a 800 x 1200 x 100mm 650kg bed at 0.1mm flat certification. It has not arrived yet so can't report whether or how much I will need to shim under my vices.
    I've also got a T Slot alloy supplier on my books we are a medical equipment manufacturer.
    Let me know if you want the contacts.
    Sent from my SM-N970F using Tapatalk
    15362
    Quote Originally Posted by Geoff Sims View Post
    Cheers
    A lot of gear in the store is not always a good sign as they are just a seller of anything, it is best to buy from just an extrusion supplier
    Mactec54
    15362
    Quote Originally Posted by boydage View Post
    Why would you even consider having to shim under a vice, you would shim the whole table off of what ever you are going to mount it on, or scrap the under side where it is being mounted, the quality is normally quite good depending on the manufacture I have had some from India and China and all have been very good I'm also waiting for one that is 1m by 2m from China
    Mactec54
    Aug 2005
    205
    How about these guys;
    https://www.isel-us.com/aluminum-ext...le-plate/pt-50
    Extruded then machined flat both sides.
    Jun 2013
    443
    Mactech has yours shipped yet?
    Jun 2013
    443
    If not your in NZ correct? We could share the LCL.
    15362
    I'm a Kiwi but live in the USA ( 30 years ) other wise yes that would of been possible, but I try and do a container load when ever I do any large shipments although they do crate them very well some use a steel pallet for the base as it is better and cheaper than wood
    Mactec54
    Jun 2013
    443
    Currently there are so many people coming back to NZ we are filling up the country.
    Hey so FYI the table I bought cost US$1500 a lot cheaper than the others but this factory make a lot of them. Hebei Yuanpeng Tool Co. Have hijacked this post but all the same interesting
    15362
    5 million and counting still have plenty of sheep though
    Mactec54
  1. New cnc machine - Mostly for aluminium
    By fransfourie in forum South Africa Club House
    Last Post: 05-05-2016, 06:39 AM
  2. Aluminium machine 1.5mX1m
    By kostas1 in forum DIY CNC Router Table Machines
    Last Post: 08-10-2013, 12:40 PM
  3. Machine number 2 all aluminium
    By matth in forum DIY CNC Router Table Machines
    Last Post: 01-29-2009, 05:27 PM
