585,987 active members*
4,623 visitors online*
IndustryArena Forum > CNC Electronics > Leadshine > MX4660 with UC100 and UCCNC. Need help with output 1
    Hello Everyone.
    I am building my first CNC Plasma table. I am using MX4660 with UC100 and UCCNC software.
    I am currently trying to wire in a 12v relay, I have it wired as follows.
    power supply 12V + to Relay coil +
    Relay coil - to MX4660 Output 1 +
    MX4660 Output 1 - to power supply 12V -
    (I have also tried wiring backwards.)
    In UCCNC I have configured spindle M3 Relay to PIN 17 PORT 1.
    According to everything I read when I press the torch "ON" button in UCCNC the 12v relay should trigger and close the loop between Pin 3 & 4 on the plasma cutter triggering the torch.
    However the 12V relay is not closing.
    What could I be doing wrong here?
    Am I missing anything?
    Thank you all in advance.
    May 2015
    38
    Re: MX4660 with UC100 and UCCNC. Need help with output 1
    Hello, this is Jason Peng from Leadshine, It seems I had replied your this problem by email,please check. thanks.
  1. Motors don't run - Mach3- Leadshine MX4660 - UC100 USB
    By pilotarix in forum Mach Software (ArtSoft software)
    Last Post: 05-13-2022, 06:46 AM
  2. Windows, UC100 and UCCNC not happy with each other
    By kennected in forum UCCNC Control Software
    Last Post: 09-04-2018, 01:00 AM
  3. Replies: 8
    Last Post: 04-13-2018, 08:48 PM
  4. Bobcad V24 + Gecko 540 + UCCNC + UC100
    By jcarpenter2 in forum BobCad Post Processors
    Last Post: 01-13-2016, 09:27 AM
