585,886 active members*
5,412 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > For Sale Only > Tsubaki Ground C5 ballscrews for sale
    Mar 2006
    42
    I have three Tsubaki 50mm diameter grade C5 ballscrews, double-nut zero backlash type, that are about 42-43" in length. Each end is machined, one end has a large internal hex and external metric locking screw threads, the other end has a section turned for the pulley (pulley end is floating end, I guess?)
    Still wrapped in plastic, new old stock replacements for Okuma machines.
    Reply via PM for more information and photos. I will have to re-measure lead as I can't find my notes. Bought them to rebuild an older lathe but ended up selling the lathe still configured for manual ops.
    275$ each plus shipping to you. Each screw is an easy 40lbs. Perfect for that larger CNC mill build, or retrofit-two are 42" and one 43" length.
    Mar 2006
    42
    Re: Tsubaki Ground C5 ballscrews for sale
    Got more information on these screws.
    Two are new, one is *probably* used. These are supposedly for an Okuma MV-40B VMC. 40mm diameter ballscrews.
    I'll drop the price to 75$ each, I'm getting tired of tripping over these things.
  1. Completed BF20 Conversion BT30 spindle, ground ballscrews
    By Winnfield in forum Benchtop Machines
    Last Post: 03-28-2013, 09:17 AM
  2. Imperial ballscrews 1in Dia x 0.200 Pitch - C5 precision ground
    By dwalsh62 in forum News Announcements
    Last Post: 12-18-2012, 06:57 AM
  3. Help me select some ground ballscrews please and other stuff
    By seanreit in forum Uncategorised MetalWorking Machines
    Last Post: 05-30-2008, 02:50 PM
  4. Machining/Turning the ends of ground ballscrews
    By rodjava in forum Linear and Rotary Motion
    Last Post: 12-06-2007, 05:08 PM
