585,956 active members*
4,560 visitors online*
IndustryArena Forum > CAM Software > SolidCAM for SolidWorks and SolidCAM for Inventor > Error Solidcam " Gap minimum value is not in range ( muse be between 1e-06 and 1 )
    Oct 2020
    Question Error Solidcam " Gap minimum value is not in range ( muse be between 1e-06 and 1 )
    Hello
    I want to make a contour
    but i have an error message
    see image below
    https://ibb.co/r2KZfN9
    unfortunately I looked for a solution
    I have also been in the options and I have this
    https://ibb.co/Tqw3P0q
    does that sound correct to you?
    thank you for helping me please
    Mar 2017
    24
    Re: Error Solidcam " Gap minimum value is not in range ( muse be between 1e-06 and 1
    This is a setting in your SolidCAM Settings. You can correct the value in the area highlighted in the attached screen grab. This will correct this error from coming up in new files. In any of your old files that reopen you will have to correct your Part Settings or correct the value in your Chain selection window.
