585,712 active members*
3,869 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > DNC Problems and Solutions > Data Transfer Problem from PC to CNC (FANUC O-MD)
Results 1 to 6 of 6
    Hello there, please help me,
    Problem is
    Previously the machine was fine, it could transfer NC code in DNC mode, or Transfer to memory, then one day there was a problem with the cable, the cable burned (for some reason it came out of smoke, (the DB9pin cable was burned up), here I use (DB25Pin Male connector for CNC-DB9 for PC), now I replaced all the cables with new ones, and there the problems started.
    When it burned, an alarm came out as I remember alarm 100 and the control could not be pressed at all, then I searched the forum and was asked to press (DELETE KEY) while pressing power on (when the machine was turned off) the reason was to format the storage memory.
    And as a result the alarm is successful, and all previous programs stored in memory are erased, the alarm disappears.
    well after a few days the RS232 cable came (where I bought from local store ), then I started to hook it up (without changing the previous parameters) and -as usual for me, I went to the EDIT key-> PROGRAM-> I / O-> READ and LSK started blinking then the DNC software was already OK, the transmission file runs to completion, but the LSK still blinks and the data is not stored at all on the machine.
    If I stop the transmission, Alarm 86.
    The parameter settings in the CNC match the same in the DNC software.
    But when receive data (nc code) from the CNC to the PC it can be up and running well.
    here the CNC setting uses
    ISO = 1 I / O = 0
    Par 0002 = 00000001 (for stop bit2 in soft DNC)
    Par 0552 = 10 (for 4800 baud rate)
    For settings at DNC ??(CIMCO DNC MAX)
    COM PORT = COM5 (because I set it to use COM PORT 5)
    BAUD RATE = 4800 (As per Par 0552 in CNC)
    STOP BIT = 2 (fits in Par 0002 on CNC)
    · DATA BIT = 7
    · PARITY = EVEN
    · PORT MODE = ASCII
    FLOW CONTROL = SOFTWARE (for handshaking)
    My thanks and appreciation
    Dan.
    Sent from my CPH1819 using Tapatalk
    Aug 2009
    1570
    Re: Data Transfer Problem from PC to CNC (FANUC O-MD)
    Quote Originally Posted by mejonuki110 View Post
    ..... (the DB9pin cable was burned up),
    ...Why is maybe your 1st priority. .... check ALL Earth grounding Wires on the CNC and the PC.
    Jul 2004
    173
    The alarm 86 means the jumpers in the RS232 cable are not correct or the wrong channel.
    You can order a tester from Amazon to see if the ports are working.
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Greg Mercurio -Shop Floor Automations
    www.shopfloorautomations.com /619-461-4000
    Aug 2009
    115
    Hello,
    86 means you have the wrong connection, wrong channel or wrong parameters.
    you can look for the software cncmanager, there are some examples for connection to Fanuc controllers
    Regards
    Thomas
    Jan 2018
    1516
    Quote Originally Posted by machinehop5 View Post
    I agree with this.
    There's usually a reson why a cable burns up.
    I wouldn't have turned it back on with just adding a new cable. I'd have checked the circuits attached to it for shorts etc first.
    Comms part of things could be fubar by now.
    May 2022
    Thanks for your answer, I would like to know the resolution and detail of engraving on metal, cnc machine K6100A I want to work 8 hours a day, and my question is whether it is designed for such requirements, I hope your recommendation profecional.
    LOL Beans
  1. Replies: 1
    Last Post: 10-28-2020, 06:30 AM
  2. data transfer on fanuc 6t
    By atlasmax in forum Controller & Computer Solutions
    Last Post: 03-01-2012, 06:43 AM
  3. Problem with data transfer
    By gabba in forum Philips
    Last Post: 09-28-2010, 10:27 PM
  4. FANUC O-TD data transfer problem
    By flyfishing89 in forum Fanuc
    Last Post: 06-04-2009, 10:44 PM
  5. Fanuc 9M data transfer problem
    By YOO in forum Fanuc
    Last Post: 01-18-2007, 03:26 PM
