585,977 active members*
4,094 visitors online*
Thread: CNC issues
    Oct 2020
    CNC issues
    Hi I'm new here and haven't been able to find what I'm looking for. I had a Proma SD THC that I was having issues with and decided to remove it for now.. in doing so the way it was wired must have been more complicated then I thought. When I toggle UP /\ it goes DOWN \/ and the same on the opposite direction. I'm looking for some help as I have tried to correct it by swapping the motor wires and it doesn't change the direction. Can anyone give me some help on what I'm doing wrong? I included a Pic and I hi-lighted where the wires go from the BOB to the Driver.
    Oct 2020
    Re: CNC issues
    Okay so the guys over at PlasmaSpider were bale to help me fix this issue.
    In Mach3 under Cofig/Ports-Pins/Motor-Outputs i was able to change the Dir and this fixed my issue.
