585,556 active members*
3,507 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Bridgeport 2000 V2XT (DX-32) Drive Enable drop out problem
    Jul 2020
    4
    I have a Bridgeport V2XT Knee mill (year 2000) with original DX-32 control.
    Used to work fine, but recently have an issue where it suddenly acts like the drives are not enabled any more.
    When it happens, I can hear the "thump" when the drives loose power. So far its always happened when the machine is not moving.
    After it happens, the software still thinks the drives are enabled, but no attempt to move the axis has any effect.
    The DX-32 software itself becomes a bit sluggish in certain places as a result also.
    The only way I've found to restore it is to reboot/cycle power.
    Has anyone seen this problem before? Id like to get an idea of whether its likely to be BMDC board, or the PC?
    I tried reseating the BMDC and cleaning the contacts, and putting in a different socket on the motherboard.
    Thanks for any ideas.
    Aug 2009
    1570
    Re: Bridgeport 2000 V2XT (DX-32) Drive Enable drop out problem
    ...20 year olds know everything..
    .check the Power supply voltage-ages to the PC would be good start. try Booting into the PC BIOS and look for any Voltage Monitoring.
    or this may help
    https://www.electronics-tutorials.ws...ch-supply.html
    Jul 2020
    4
    I checked and the bios does have voltage measurements. All but the +12 looks ok. The +12 says 11.24. That could well be a problem. See screenshot.
    I'll look into replacing the supply.
    Aug 2009
    1570
    ...thats good your MB has a PC Health page. Looks like the CPU VCore is a little low too, should be 1.25-1.35 range. I also see the VBAT 2.89 which is the CMOS Battery backup on the motherboard. (I think) should be above 3.1v or so. Maybe it would be a good idea to make a List of ALL the Bios settings before doing anything with the Battery or Power Supply. Backup ALL your Parameters and HDD too while the machine is still running ok.
    enjoy,
    DJ
  1. Bridgeport Interact 1 Mk2 - spindle drive problem
    By AdeV in forum Bridgeport / Hardinge Mills
    Last Post: 04-15-2019, 02:15 PM
  2. Bridgeport Interact 1 Mk II - Ktk Drive Problem
    By palikalsi in forum Bridgeport / Hardinge Mills
    Last Post: 03-23-2015, 12:50 PM
  3. V2xt bridgeport
    By diyengineer in forum Bridgeport / Hardinge Mills
    Last Post: 10-05-2014, 08:04 AM
  4. Bridgeport V2XT w/DX32 Control Center Attached. Drive Fault Errors
    By creaton in forum Bridgeport / Hardinge Mills
    Last Post: 06-09-2014, 06:28 PM
  5. V2XT: Spindle Enable dead fault.
    By 9 1/2 in forum Bridgeport / Hardinge Mills
    Last Post: 03-24-2008, 03:57 PM
