586,024 active members*
4,338 visitors online*
IndustryArena Forum > MetalWorking Machines > Knee Vertical Mills > Anilam Encoder/ scales wiring
Results 1 to 7 of 7
    Oct 2020
    5
    I have a Lagun ftv2 that originally had a crusader M cnc unit on it but the previous owner removed it, along with just cutting the wiring to the Anilam A2 scales on it. I contacted Accurite for a pin out / wire color conversion to a dsub9 but what I was given doesn't work. Can anyone help with this?
    Also, this machine didn't come with a drawbar (just a plate over the area where it would). I'd like to add one to it, as I don't like the locking collar that's on it. If anyone has the manual or parts list for the ftv2 I would greatly appreciate it.
    Dec 2013
    5717
    Re: Anilam Encoder/ scales wiring
    It could be that the scales are damaged and just don't work. What are you trying to connect them to?
    It's pretty easy to make a draw bar. The really easy way is to buy a stick of B7 or Grade 8 all thread of the proper thread, and just cut to length.
    Jim Dawson
    Sandy, Oregon, USA
    Oct 2020
    5
    Trying to connect them to just a cheap 3-axis DRO. You might be right about them not working but I'd still like to try and keep them. I know they originally had a round 7 pole aviation connector.
    The drawbar isn't the issue. I need to determine if there are anymore pieces missing or added because this machine didn't have a drawbar ever.
    Dec 2013
    5717
    What are the wire colors that you have? Maybe a part # on the scale? I'm pretty sure that Anilam scales used 5V quadrature output and a 5 micron resolution, so should be compatible with most modern DRO's
    The only parts I have ever seen in a drawbar is the screw, the top nut (pinned to the screw), and a washer. The drawbar just contacts the top of the spindle. Not all spindles have the through hole for the drawbar. I have seen some #30 and #40 spindles, when equipped with a quick change nose, that did not have the through hole.
    Jim Dawson
    Sandy, Oregon, USA
    Oct 2020
    5
    Thanks for the info on the drawbar. I'll have to look at the head and check for the through hole.
    This is the only label I can get to on the scales.
    https://www.dropbox.com/s/t3y04g0x90...14934.jpg?dl=0
    It's 9-wire + shielding. Red, blue, pink, green, brown, black, white, grey, yellow
    Dec 2013
    5717
    As best I can find this should be the correct wiring
    A Green
    /A Yellow
    B Blue
    /B Red
    I Gray Not Used
    /I Pink Not Used
    5V+ Brown
    Gnd White
    Black Not Used
    Jim Dawson
    Sandy, Oregon, USA
    Oct 2020
    5
    TY I'll give that a try.
  1. Want Anilam Z-Axis Encoder BEI
    By calmissile in forum Want To Buy...Need help!
    Last Post: 09-04-2018, 05:49 AM
  2. Anilam Crusader M: Encoder reads 4:1, scales 1:1
    By Hythos in forum Controller & Computer Solutions
    Last Post: 05-16-2014, 07:14 AM
  3. Interfacing scales and encoder to LPT port.
    By Galane in forum CNC Machine Related Electronics
    Last Post: 04-02-2014, 11:41 AM
  4. Wiring Advice linear scales
    By electromech31 in forum Knee Vertical Mills
    Last Post: 03-10-2011, 02:43 AM
  5. Converting Anilam to Mach3 - Pixie and Glass Scales
    By czech in forum CNC Machine Related Electronics
    Last Post: 01-01-2009, 10:16 PM
