585,735 active members*
4,871 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > What is the smallest router bit for cutting wood for a CNC machine?
    Oct 2020
    9
    Hello,
    I am looking for the smallest diameter router bit available for a CNC machine. What is the smallest router bit you can buy? I'm cutting designs in wood that have some pretty small details. Thanks for your help!
    Nov 2020
    Re: What is the smallest router bit for cutting wood for a CNC machine?
    Hello, Here I can buy the smallest woodworking router bits as follows:
    Drill Diameter: 2mm
    Shank Diameter: 6mm
    Cutting Flute: 2
    It's a TCT straight router bits.
    If 2mm drill diameter is okay, you can check more information by this link:
    https://www.konetool.com/Double-Flut...outer-Bit.html
    What drill diameter can fit your work?
    Nov 2009
    14
    It's easy to find 0.4mm end mills for sale.
    Trust me, they're much smaller than you could possibly use in your projects.
    If they're not, by some magic, I can look around casually and find smaller ones... to the tune of 0.1mm. If you cough while the mailman is delivering them to your house, they'll arrive broken.
  1. Replies: 0
    Last Post: 07-18-2020, 03:00 AM
  2. Replies: 0
    Last Post: 07-11-2020, 05:14 AM
  3. Replies: 0
    Last Post: 12-24-2019, 02:47 AM
  4. smallest cnc router CR2030 for Plywood cutting
    By SPC-laser in forum News Announcements
    Last Post: 01-22-2013, 03:41 AM
  5. What's the smallest size tool that be used to machine wood?
    By neeboy in forum DIY CNC Router Table Machines
    Last Post: 04-29-2010, 10:50 AM
