531,852 active members*
2,637 visitors online*
IndustryArena Forum > WoodWorking > General WoodWorking > What is the smallest router bit for cutting wood for a CNC machine?
Results 1 to 2 of 2
    Banned
    Oct 2020
    9
    Hello,
    I am looking for the smallest diameter router bit available for a CNC machine. What is the smallest router bit you can buy? I'm cutting designs in wood that have some pretty small details. Thanks for your help!
    Member
    Nov 2020
    Re: What is the smallest router bit for cutting wood for a CNC machine?
    Hello, Here I can buy the smallest woodworking router bits as follows:
    Drill Diameter: 2mm
    Shank Diameter: 6mm
    Cutting Flute: 2
    It's a TCT straight router bits.
    If 2mm drill diameter is okay, you can check more information by this link:
    https://www.konetool.com/Double-Flut...outer-Bit.html
    What drill diameter can fit your work?
  1. Replies: 0
    Last Post: 07-18-2020, 03:00 AM
  2. Replies: 0
    Last Post: 07-11-2020, 05:14 AM
  3. Replies: 0
    Last Post: 12-24-2019, 02:47 AM
  4. smallest cnc router CR2030 for Plywood cutting
    By SPC-laser in forum News Announcements
    Last Post: 01-22-2013, 03:41 AM
  5. What's the smallest size tool that be used to machine wood?
    By neeboy in forum DIY CNC Router Table Machines
    Last Post: 04-29-2010, 10:50 AM
