585,975 active members*
4,614 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Fadal VMC15XT Unrecoverble memory error at 0742 at start up?
    Oct 2020
    Hello All,
    New user from Sydney Australia and new to CNC milling, Trust all is well in these unprecidented times.
    Have just bought an old Fadal, 1996 VMC and upon power up find I cannot do much of anything?
    First off memory error at 0742, use 'NE' CMD to clear.
    Do that then get, do u want to clear memory, I say yes?
    Then I get new error 0021? Use 'NE' cmd to clear memory. And from there it just does the same thing over and over?
    Any knowledge would be greatly apreciated, thinking I should change battery but machine was working only a couple of months ago? But might help.
    Also the bed was physically moved whilst pushing into possition, hence the next error that shows occasionally which is memory need to be zeroed, but this standard Fadal proceedure does not work at all?
    Kind regards,
    Zev
    Aug 2009
    1573
    Re: Fadal VMC15XT Unrecoverble memory error at 0742 at start up?
    ...does sound like a Battery problem is the cause of memory errors. But, might try doing the Zero Memory (Step 7 n 8) to see if the machine will start.
    https://www.fadalcnc.com/media/pdf/Z..._Procedure.pdf
    Also, when replacing Battery see the Video below for a good tip about how to pig tail the new Battery leads for easy install.
    long video start watching at about 3:30
    Oct 2020
    Hi M5,
    I replaced the battery this morning and discovered I was missing spindle encoder and the bung up inside the machine housing, one with multiple terminal ends.
    Set all this up and did your zero memory proceedure and I now have some signs of life!
    Able to JOG table and did a CS but at end is now saying numbers out of range?
    Have not yet been able to dry run spindle but that is probably due to my lack of knowledge and early stages of learning.
    Otherwise lloking promising now, many thanks!
    Zev
    Aug 2009
    1573
    ...thats good news. The factory parameters for your machine are written down inside the Pendant Door (hopefully) use SETP to change them
    https://www.fadalcnc.com/media/pdf/t...Parameters.pdf
    Oct 2020
    sORRY LOSTTOUCH FOR A WHILE, FOUND THAT THANKS HAVE IT ALL WORKING NOW, EB=VEN REPLACED THE ENTIRE Z AXIS SCREW.
  1. So how much is a Fadal VMC15XT worth these days?
    By Houndogforever in forum Fadal
    Last Post: 09-21-2016, 06:53 AM
  2. Fadal vmc 15 Memory error
    By Daniel Boone in forum Fadal
    Last Post: 01-14-2015, 02:34 AM
  3. Fadal Memory Error
    By Antonio Arguijo in forum Fadal
    Last Post: 06-23-2010, 06:22 PM
