585,981 active members*
4,478 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Mach3 4th axis capable of rotating 360 degrees. Post requirement
    Mar 2020
    Exclamation Mach3 4th axis capable of rotating 360 degrees. Post requirement
    https://www.youtube.com/watch?v=zng1Vh-BC9I
    https://www.youtube.com/watch?v=CseHVvv3tWQ
    Hello friends. I designed the 4th axis that can rotate 360 ??degrees.
    You can see it in the video. Currently I can run it manually. No mechanical problems.
    I want to program side hole jobs in cad / cam software.
    I tried on my alpha, but I don't have a post.
    I couldn't get g code due to post incompatibility I know very little about software and post.
    I want to drill holes on 4 sides of a panel.
    I plan to do this by rotating 90 - 180 - 270 - 360 degrees.
    Please help me with this.
    Jun 2010
    4256
    Re: Mach3 4th axis capable of rotating 360 degrees. Post requirement
    Can you skip the CAD/CAM and program directly?
    I routinely drill 4 holes in a part at 90 degree intervals using the A axis, but I program all that by hand.
    Cheers
    Roger
    Mar 2023
    Quote Originally Posted by endless View Post
    I want to program side hole jobs in cad / cam software.chat gpt login
    The author's ability to make connections between seemingly disparate topics is remarkable.
  1. X and Y axis not 90 degrees
    By dkerr in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-14-2019, 08:43 AM
  2. rotating mill work on sub spindle 90 degrees
    By Drake75 in forum G-Code Programing
    Last Post: 03-27-2013, 03:02 PM
  3. Looking for 3 axis CNC capable of Ti machining
    By scottmansonak47 in forum Want To Buy...Need help!
    Last Post: 03-01-2013, 04:27 PM
  4. 4th axis degrees of rotation.
    By Wolford in forum Surfcam
    Last Post: 02-11-2012, 07:46 PM
  5. DIY 3 Axis capable of 4A?
    By Curtisbeef in forum Stepper Motors / Drives
    Last Post: 05-21-2008, 07:31 AM
