585,997 active members*
4,727 visitors online*
    Nov 2020
    Can't find GPPTool directory
    Hello guys,
    I'm passing through some errors with arcs on SolidCAM and after some time on the internet searching and studying about it, seems I've found a solution, edit the .gpp file, increasing the arcs precision on postprocessor. My problem here is, I can't find the .gpp files on the directory that they should be (GPPTOOL).
    This folder doesn't exist, have you ever seen this before?
    I'm using SolidCAM 2018 SP0 on Windows 10
    Thanks!
    Mar 2017
    24
    Re: Can't find GPPTool directory
    First thing I would say is have your local reseller's Post Processor team handle any changes to your Post. If you want to do this yourself then you can find where you Posts are keep or at least being searched for by SolidCAM in the attached screen grab. Your folders may have been moved around and that is why you can not find the GPPTOOL folder by this address in your SolidCAM Settings is where your SolidCAM is looking for the Post files.
    Quote Originally Posted by MuTech View Post
    Hello guys,
    Thanks!
    ola boa noite , vc abre Windows explore, unidade C/: usuário , publico ,documento publico. Solidcam, Solidcam 2018 , gpptool.
    aconselho copiar e renomear o arquivo para nao perder a origem.
  1. Gpptool trace level
    By Wrighter in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 03-27-2021, 12:53 PM
  2. Gpptool trace level
    Last Post: 10-24-2018, 03:50 PM
  3. How to delete old directory files & Add all new directory & tool library
    By mikepaul29 in forum Uncategorised CAM Discussion
    Last Post: 08-29-2014, 02:17 AM
  4. GPPtool error
    By pinguS in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 11-16-2009, 09:06 AM
  5. TurboCNC can't find directory
    By thuffner3 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-06-2004, 04:30 AM
