585,978 active members*
4,441 visitors online*
IndustryArena Forum > Community Club House > Machinist Hangout > Endmill for cutting 1mm aluminum sheet
    Sep 2020
    12
    Hello.
    What type and size endmill/endmills would I use to cut 1mm aluminum sheet and also make #6 screw holes which are around 3.3mm in diameter. I'm making a guitar pick guard and I'm trying to learn to cut aluminum on a Millright Carve King with a Dewalt DPW611 router and the lowest speed is 16000 rpm which I know it's not ideal for aluminum. I've read that 1 flute cutters are great for aluminum.
    Thank you
    Joz
    Nov 2020
    Re: Endmill for cutting 1mm aluminum sheet
    With a variable speed controller you can adjust the rpm way down without loosing torque.
  1. Aluminum sheet cutting on router
    By Funkyjunk in forum MetalWork Discussion
    Last Post: 09-18-2010, 08:00 AM
  2. Cutting aluminum sheet
    By Smokingman in forum MetalWork Discussion
    Last Post: 06-16-2010, 05:28 PM
  3. 4X8 CNC router cutting 3/16 aluminum sheet
    By scorpionracing in forum Uncategorised MetalWorking Machines
    Last Post: 02-22-2010, 10:47 PM
  4. 1/32 Endmill cutting aluminum?
    By DennisCNC in forum MetalWork Discussion
    Last Post: 12-27-2005, 06:22 AM
  5. Having trouble cutting aluminum sheet
    By fastturbovet in forum MetalWork Discussion
    Last Post: 06-15-2005, 04:33 AM
