585,604 active members*
3,361 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Quick question on CNC conversion ball screw maintenance , PM25 arizonacnckits
Results 1 to 5 of 5
    Hi -
    Looking for some quick feedback / info on how often its needed to lube a ball screw given the use conditions below:
    - Purchase the kit https://www.arizonacnckits.com/pm-25-cnc-kit.html and install
    - Use the mill about 2h per week on average.
    - Nothing crazy, Alum and plastic. Low to med loads.
    How often would I need to oil (grease ?) the ball screw nut via the port/fitting?
    I did a search, but some threads are over a yr old.
    https://www.cnczone.com/forums/taig-...0-cnc-cad.html
    thanks in advance.
    AG
    (PS if there are any other maintenance tips on the ball screw, feel free to share a link)
    Aug 2009
    1570
    Re: Quick question on CNC conversion ball screw maintenance , PM25 arizonacnckits
    ...yes Mobil Vactra #2 is about the most common waylube oil used. But, maybe grease is a better option with some conditions.
    https://www.thomsonlinear.com/downlo...ation_tauk.pdf
    Well thankyou for the PDF. Based on that particular brand, they recommended:
    "As a rule of thumb, replenish grease at least every 600-800 hours"
    So with my Mill / usage and the low hours of only 2-3 per week... it suggests I could lube every 1-2 yrs or even more. (But prob best to go longer as it could dry out)
    AG
    I run way oil but never added it to my ball screws. I don't grease them very often. Maybe annually. The Z screw stays pretty clean. As does X. The Y-Axis screw is probably the one that needs the most maintenance.
    I'd think some nice way covers would make a big difference.
    Thanks CL_MotoTech, that's what I'm thinking too, annually.
    Good tip on the way covers. Have them now, will make sure they do the job.
    AG
  1. Ball screw maintenance
    By NicMarsha11 in forum Linear and Rotary Motion
    Last Post: 09-20-2020, 04:11 PM
  2. Conversion of Momus to ball screw for X and Y
    By raynorj in forum Momus Design CNC plans
    Last Post: 05-12-2019, 09:09 PM
  3. Another Taig ball screw conversion !
    By protrackcorp in forum Taig Mills / Lathes
    Last Post: 11-18-2016, 07:46 PM
  4. Ball Screw Source for Conversion
    By RTP_Burnsville in forum Linear and Rotary Motion
    Last Post: 12-30-2006, 11:39 PM
  5. Mini Mill 5/8 Ball Screw conversion Question
    By rustyolddo in forum Benchtop Machines
    Last Post: 12-12-2004, 07:24 AM
